67 GTO 4 BBL Throttle cable bracket fitment
The bracket that I have, a repro from APE years back, which I'm pretty sure I used, again years back, when I was running the original carb and intake, seems to not reach the intake if I have it sitting on the upper mount hole. There is about 1/4" space between the mounting hole and the intake.
Is this the correct piece? or am I forgetting something that fits under it between it and the intake?
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 Last edited by vidguy; 07-02-2017 at 06:00 PM. |
ahhhhhhh
it requires a bolt with a stud on top so it accepts a nut
the nut is the 1/4 inch space you describe ... I can mail you one Scott |
Thanks Scott. I'll take you up on that.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
bolt
got your note with address also ... perfect ..... it will go out wednesday usps its the lower one in the picture .... this is actually a 70 n up drivers side front alternator bracket studded bolt it will work just fine under your bracket ... did you have a your GM stubby upper bolt ? Last edited by Scott Thelander; 07-03-2017 at 09:04 PM. |
The one that goes on the water neck? Yes I do. It is similar to that, so that the alternator bracket will mount to it. Or do you mean the small bolt that mounts to the pedestal on the manifold in the upper little hole in the bracket? For that I scavenged one from my box o' bolts
throttle bracket to intake .. the one thats easy to see
I should have said short bolt for the other throttle bracket mount... Scott |
I have one that fits there. Thanks!
TOO late
I already put a real one in the package ...
Scott |
Well that's cool thanks a lot!
Still looking for advice on what might be wrong with my setup. I measured the cable and it is 20 1/2" it wold fit if it mounted in the bracket more Forward than it does now.
For example, if I put the cable under the little bracket instead of the metal end (the bell shared ferrule) and have the metal ferrule out of the bracket entirely, it its perfect..If anyone has any experience with these brackets and cable lengths, let me know.
Just thinking out loud... is it possible the bracket is for a two barrel?
Primaries are more centered versus Q-Jet being further forward |
I have a pair of original '67 GTO cables I can check for you. Probably can get my hands on the brackets too. However it will probably be the weekend before I can follow up and get to them.
I will say that now after having spent time messing with this; The holes don't line up very well. If I bolt the top down, I can see that the lower hole on the bottom of the bracket is not centered over the lower bolt hole. It does not appear I have bent the bracket in the past. It looks "as stamped". Bad Repro part or wrong repro part...? edit: After looking at pics on a few sites I think I have a 65-66 4 bbl bracket, and possibly the wrong cable... I'm going to try a new (used) bracket first.. I'd still like to see your parts 400.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 Last edited by vidguy; 07-06-2017 at 04:25 PM. |
FWIW my '67 doesn't use a spacer under the bracket. It's sits flush in both locations. This is an unrestored car btw.
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too |
2bbl and 4bbl brackets are different
