radiator core support mounting bushing sequence
What is the correct sequence for the radiator core support rubber mounting bushings? Is it:
Cage nut big washer top rubber bushing bottom of frame channel bottom rubber bushing bottom of core support big washer bolt OR do the two rubber bushings sandwich the bottom of the core support and the cage nut sit directly on the bottom of the frame channel? I pick door #2. |
Sent from my iPhone using Tapatalk |
Perfect, Dave. Thank you.
Where did you find that? I looked through the workshop manual, the Fisher Body Service Manual and the assembly manual (obviously not carefully enough). |
That was in the assembly manual, can be a bear to find stuff in that thing.
I just had to save that for later. Thanks
"Honestly the car will only be there for a few weeks, OK maybe a month at the most" |
Of course, the Assembly manual. I should have looked closer. Darn.
Thread Tools | |
Display Modes | |
