Looking to buy used original centerlink from a 64-70 A body
Any condition okay. Will use them for research and experimenting on...it will never be mounted in a car.
I have used steering linkage for A bodies. Where are you located? Thanks, Bob.
Robert 6d7gto@gmail.com |
Email sent.
I haven't heard back from you Bob. Did you forget me? If shipping is a problem, just cut off the ends of the center link with a cut off wheel. Will pay up to $50/each end for original parts that have good threads on the tapered stud.
Robert, I didn't forget. Initially you posted "Looking to buy used original centerlink from a 64-70 A body" After I responded by email you told me that you needed them labeled by the year that they were off of, with a preference for '66-'67. Mine are not marked as such, so I didn't pursue it. I apologize for not updating you.
https://forums.maxperformanceinc.com...d.php?t=856393 #6 post by gto4ben has photos of what original parts look like. These are from the smaller diameter A body center links with 13/16" diameter. These have the smaller studs shown in photo 2. Photo 1 shows what the end cap looks like after the capture ring (looks like a washer) was ground down. Original center links have date codes stamped in them which is evidence they are original production units. I'm guessing other GM center links of that era (with the smaller diameter) utilized the same set up and parts for the end links. So if you're not sure if they are from a Pontiac, I would still be interested in buying just to take them apart. |
Need original center links from 64-70 A body
Still looking for center link...parts or whole. Will pay $50 or more per side depending on condition.
Hello
Sent from my iPhone using Tapatalk |
Would other A-bodies be the same? I have a 64 Skylark parts car that I could pull the center link off of.
Importsmasher
Scott Baggiore 66 GTO convertible 389/4 speed (parents bought new) 73 Firebird Formula 400/4 speed 74 GTO 455/4 speed 74 Grand Am |
Not sure...but I found what I needed already. Thank you for responding.
Thread Tools | |
Display Modes | |
