Old 04-20-2022, 12:08 AM
58pontiacambulance 58pontiacambulance is offline
Default It's not low enough
So new here. Thanks for the acceptance. A little about my build
1958 pontiac superior chief ambulance
Stock 15" wheels, stock suspension components except its bagged (some will hate some will love. Just remember I built this for me nobody else)
6.0 ls 4l80e trans
My question. Is being it's a 58 and a pain to find aftermarket support on suspension components. Has anyone swapped spindles to something that has more options? I. Wanting 2" drop spindles so that I can lay frame
ID:	588988   Click image for larger version
ID:	588989   Click image for larger version
ID:	588990   Click image for larger version
ID:	588991   Click image for larger version
Old 04-20-2022, 11:51 AM
JLMounce JLMounce is offline
I am not 100% sure, but I think these might work for you. https://www.speedwaymotors.com/RideT...dy,337799.html
-Jason
1969 Pontiac Firebird
Old 04-20-2022, 12:11 PM
Unfortunately I don't think those will work as chevy had different ball joints. Pontiac uses an oddball 58 only balljoint
Old 04-20-2022, 12:16 PM
Pretty common Pontiac practice to do stuff like that. You may have to look at putting the chevy arms on the car. I've dealt with this on my 69 bird which has 1 year, 1 manufacturer only parts all over it. In general it's almost always necessary to put the chevy variant part on the car to get it to do what you want.
That doesn't work out well for concourse and factory correct restos, but in my case, and your case, the cars are far from factory, so that's not really a concern.
-Jason
Old 04-20-2022, 12:36 PM
1958 is a one-year spindle too. We have a bunch of engineering sample spindles, Chevy B's included (but no 1958).
Measure the height of the 58 spindle and will compare it to out sample and go from there. This spindle swap may also change your bolt pattern too.
Old 04-20-2022, 01:55 PM
Stuart's Avatar
Stuart Stuart is offline
Fatman Fabrication has dropped spindles in their catalog, but only up to 1957. I *think* they may also do one-off custom work, you could give them a call. https://www.fatmanfab.com/dropped-uprights-spindles
Old 04-20-2022, 02:10 PM
Steering arms won't interchange - 3.125" vs. 3.800" spacing and Impala's are front steer.
Old 04-22-2022, 04:21 PM
misterp266's Avatar
First of all, welcome and I really like your car.
Have you considered cutting off the frame at the firewall and putting on a later model front frame section?
Maybe add a rack and disc brakes at the same time. Would probably be the easiest way in the long run. Considering you’ve committed to an LS motor, an upgraded front end would be a good idea.
Post more pics . . . . .😎
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post:
Old 04-27-2022, 10:53 AM
Cutting the frame and stubbing it isn't an option. I have thought about it though. Just don't want to get that radical with the frame mods as it sits right now with the airbags if I ever wanted I could put the stock springs back in it and put it back to stock
Old 04-27-2022, 12:26 PM
big matt's Avatar
big matt big matt is offline
I dont know a lot, and i dont have any answers for you, but that 58 is cool as can be. Welcome!
1970 Formula 400 4 speed
2006 Gto. Ls2/m6
1972 Gto 455ho/th400 post coupe
1973 Grand Am 400 4 speed
The Following User Says Thank You to big matt For This Useful Post:
Old 04-27-2022, 12:29 PM
I’m guessing the majority of guys whose cars can lay frame are doing some pretty extensive mods to their chassis and body.
I’d be happy where you’re at, getting down much further gets into heavy and more costly mods.
Old 04-27-2022, 12:31 PM
Ironically I'm only about 1/2 inch from laying frame and that's what I'm trying to get to. I don't want to modify the body to drop it down over the frame. Even though it would look better
Old 04-27-2022, 12:35 PM
Tires that are 1” smaller in diameter or more will get you there. Maybe switch to 14” wheels with the same tire size.
I realize replacing good tires isn’t what most would want to do but the next time you’re buying a set that would e something to consider.
Old 04-27-2022, 02:09 PM
misterp266's Avatar
Just weld 1/2 plate to the bottom of the frame . . . .. Or not . . . .
" Darksiders Rule "
Old 04-27-2022, 03:18 PM
Nobuddy Nobuddy is offline
Nope. Bolt on 1/2" titanium skid blocks/landing pads
Old 06-05-2022, 05:48 PM
steves1967 steves1967 is offline
Could you swap out the body bushings to get the car to sit lower on the frame? I know its not "laying frame" but the overall image would be the same.
Old 06-05-2022, 06:25 PM
ponchonlefty ponchonlefty is offline
cool ride . do the ambulance have the x frame ?
