Old 02-07-2021, 09:44 PM
andy kelleman andy kelleman is offline
Default Rear suspension 1973 Ventura bracket car
1973 Ventura bracket car leaf springs slidolinks 12 bolt w/spool 501 w/power glide 4500 converter 3.73 gear car weighs 3090 with 1/2 tank of fuel 3250 with driver run 6.40 to 6.50 1/8 mile methonal 4500 Rupert Holley rear springs are 5 leaf stock type I was thinking of switching to cal tracs and slider boxes instead of shackles rear of car is to stiff very hard on rear tires it works but I think it could be way better can I use stock type spring with less leafs or should I switch to cal trac springs also car has qa1 coil over shocks up front looking for suggestions rear tires are Hoosier 29/10/15 thanks bigk
Old 02-07-2021, 11:04 PM
GTOGEORGE's Avatar
Ladder bars.....been there.... done that!
GTO George
Old 02-08-2021, 09:13 AM
Gary H's Avatar
Gary H Gary H is offline
I recently put a set of Cal Traks on a customers 79' Trans Am street car. What a difference! The car wouldn't hook up at all before. It will plant the tires and scoot now, all on street tires. I was impressed!
Old 02-08-2021, 01:04 PM
bpenrod bpenrod is offline
Caltracs will work well for you.
Old 02-08-2021, 02:19 PM
firechickenman's Avatar
firechickenman firechickenman is offline
Caltrac springs, Caltarc bars and some good double adjustable shocks would make a huge difference.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 02-08-2021, 03:37 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
You won't need rear sliders, shackles will work fine. When set up with Caltrac's, the rear will be just as stiff as it is now. They do not allow the rear to squat one bit.
Less said,,,,,,,, Less mended.
Old 02-11-2021, 06:44 PM
Any body running ce slide o links ?
Old 02-11-2021, 07:08 PM
ErikW's Avatar
ErikW ErikW is offline
Spend the money on Caltrac springs and bars.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
