Old 04-15-2021, 02:02 PM
JLuger's Avatar
JLuger JLuger is offline
Checked that looks like stock mount couldn’t go any lower because of linkage.
Old 04-15-2021, 02:06 PM
HWYSTR455's Avatar
A little can make a lot of difference, the one poly trans mount I had moved the front down an inch or more.
Just figured I'd throw it out there, so you're not overlooking a potential cause.
Old 04-15-2021, 04:05 PM
JLuger's Avatar
Absolutely appreciate all the help.
Seems like everything I run into usually someone’s already been there.
Old 03-03-2022, 09:07 PM
lugnutx2 lugnutx2 is offline
I had the same issue with my 66, I was told the frame was probably tweaked, I didn't buy that idea. It turns my new motor mounts were setting the engine too low in the cradle, I found some REALLY old NORS stock mounts, they fixed the problem! I see AMES now sells stock mounts that are supposed to be dead on to the originals, I'd try those before I bought their 1/4 spacers.
Old 03-03-2022, 10:14 PM
JLuger's Avatar
I actually made a couple of spacers that worked but ended up changing the mounts gd to go. The mounts were the problem.
Old 03-03-2022, 10:19 PM
ZeGermanHam's Avatar
Which mounts did you end up using that worked?
1998 BMW 328is (track rat)
Old 03-04-2022, 10:46 AM
JLuger's Avatar
I used the Ames Torq lok
Thread Tools
Display Modes
