Old 10-22-2021, 11:58 AM
Default New and used parts update (72 Lemans plus other years)
New and used parts still available.
New:
Transmission mount, Anchor #2378 ($5). Front seat belt bolts (2) plus 2 used ($5). Core support and rear body mount bushings w/hardware ($5). Trans lines frame clip, paid $12 ($5). Center console door spring, paid $12 ($8). Accelerator cable grommet ($2). Rear hood stainless molding (68-72), has small dent on passenger side ($15).
Used:
Trunk latch w/bolts, very nice, 64-72 ($30). POA (AC))valve clamp and screw ($5). Exhaust hanger and clamps ($3). Rally 2 trim rings with clips on back, 2 1/4" (4) ($10). Pontiac grill nameplate, straight, good studs with nuts ($15). Driver side door latch assembly with rod ($20). '73 AC brackets, front and top passenger side ($10). Steering wheel center horn assembly with contacts ($20). Single window crank handle w/ door washer/spring/clip ($3). Passenger inside door handle ($10). Driver side top rear fender extension molding w/ bracket and screws ($15). Top rear fender extension molding brackets ($5). Door/window hardware (stops, guides, bolts, washers, etc.) ($15). Passenger front lower door hinge ($20). Convertible driver side windshield pillar post rubber seal, nice ($10). Emergency brake to body rod ($5). Q-jet carb float ($2). Door striker washer ($1).
ID:	575815   Click image for larger version
ID:	575816   Click image for larger version
ID:	575817   Click image for larger version
ID:	575818   Click image for larger version
Old 10-22-2021, 12:01 PM
Default New and used continued
More pics.
ID:	575820   Click image for larger version
ID:	575821   Click image for larger version
ID:	575822   Click image for larger version
ID:	575823   Click image for larger version
Old 10-22-2021, 12:03 PM
More pics.
ID:	575825   Click image for larger version
ID:	575826   Click image for larger version
ID:	575827   Click image for larger version
ID:	575828   Click image for larger version
Old 10-22-2021, 12:12 PM
Default Continued pics
More pics.
ID:	575835   Click image for larger version
ID:	575836   Click image for larger version
ID:	575837   Click image for larger version
ID:	575839   Click image for larger version
Old 10-22-2021, 12:16 PM
Default Even more pics
Continued.
ID:	575841   Click image for larger version
ID:	575842   Click image for larger version
ID:	575843   Click image for larger version
ID:	575844   Click image for larger version
Old 10-22-2021, 12:19 PM
Default Still more pics
Sorry so long. More.
ID:	575846   Click image for larger version
ID:	575847   Click image for larger version
ID:	575848   Click image for larger version
ID:	575849   Click image for larger version
Old 10-22-2021, 12:23 PM
Default Still more to come
Continued
ID:	575852   Click image for larger version
ID:	575853   Click image for larger version
ID:	575854   Click image for larger version
ID:	575855   Click image for larger version
Old 10-22-2021, 12:27 PM
Default Ok more pics
More
ID:	575857   Click image for larger version
ID:	575858   Click image for larger version
ID:	575859   Click image for larger version
ID:	575860   Click image for larger version
Old 10-22-2021, 12:32 PM
Default More parts pics continued
more
ID:	575862   Click image for larger version
ID:	575863   Click image for larger version
ID:	575864   Click image for larger version
Old 10-26-2021, 12:35 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
PM sent
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 10-27-2021, 06:03 PM
Steering wheel center horn assembly SOLD! Thanks.
Old 10-30-2021, 09:18 AM
Trans mount, core support/body bushings, and window/door hardware SOLD! Thanks.
