Vacuum advance source
Is the carb stud on a Q-Jet a suitable source for manifold vacuum for ignition advance?
I'm World's Best Hyperbolist !! |
Are we talking on a stock duel plane intake?
I do stuff for reasons. |
No, that's not my first choice. Although I used to use it to seal the distributor end of the vacuum-advance vacuum hose when setting timing. |
This one. Used on 68 Manual Transmissions. Possibly others.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
The Following User Says Thank You to OG68 For This Useful Post: | ||
I'd expect that to be manifold vacuum. Test it and see.
If so, and you want manifold vacuum for your vacuum advance, that'd be fine. That's not a vacuum source I'm familiar with. Is there a missing nut on that stud to hold the carb base against the gasket? |
Yes the one in the photo is missing the nut.
Basically it's just a hollow stud that goes into that intake runner.
Normally Vacuum Advance gets a balanced vacuum from both sides of the carb where it mounts on the divided wall of the carb. If you put it on a carb stud you get one half of the signal to the vacuum advance. Suction, space, suction, space, suction, space.
At the back of the carb, you get signal from BOTH intake manifold "Planes" and a continuous signal to the vacuum can. There is also a fitting on a stock Pontiac dual plane intake that "reads" vacuum signal on both planes. Tom V.
The Following 4 Users Say Thank You to Tom Vaught For This Useful Post: | ||
Thanks Tom, exactly what I wanted to know. I have numerous options for a source, this one was just the easiest.
What did GM use that vacuum fitting for?
As OG68 said, it was used on 68s with the five port TVS, spark retard system and manual trans ... don't think I've ever seen it used anywhere else.
Anyone know what the vacuum port on to the right of the fuel inlet on this 1971 704 carb is for? And if it would be suitable for vacuum signal to the advance can?
I'm World's Best Hyperbolist !! Last edited by dataway; 04-29-2022 at 04:16 AM. |
That's a ported vacuum source.
There's always the option of putting a Y or T into the Choke pull off line since that is aways full Manifold vacuum.
The Following User Says Thank You to 25stevem For This Useful Post: | ||
Source location is too high for ported vacuum advance at that fitting.......
The Following User Says Thank You to Cliff R For This Useful Post: | ||
if it's in the main body of the carb, it goes to the vacuum modulator on an auto trans.
“We don’t build a ‘luxury’ car. We build a performance car then we make it luxurious.” |
Talking about the port to the RIGHT of the inlet in the photo. The modulator port is on the left with the sealing barb.
This port is in the base plate. Anyone know what it was used for on a 71 Pontiac? Carb is a 7041264
It´s used for the coal canister (evaporation control system).
The Following User Says Thank You to Kenth For This Useful Post: | ||
Bingo!
If I recall right the bigger size hose that would be needed is the tip off, no?
Starting to look like the best source may be the large port on the rear ... I was only wanting to avoid that because it also supplies the power brake, AC system, and headlights .. didn't want my timing changing when I hit the brakes Although I have no idea if that would happen or not.
There is a check valve in the Power Brake can that keeps the issue you describe from happening.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
My '71 Gp had a tree at the back of the carb with several ports on it. one went to the brake booster and another to the vacuum advance. never noticed it do anything funky while driving .
The Following User Says Thank You to Matt Meaney For This Useful Post: | ||
Matt ... figured you thought that ... I should have specified Pas/Drv side
Since I'm using a 71 Q-Jet I'm guessing that solution will work for me too. Engine has 20+ inches of vacuum at idle ... so there's no shortage
