Choke stove
So im.looking at my engine I my yz formula 400 and I got choke stove 8097 is that possible in 1970? Will it work correctly on carb 7040270 or do I need 0097 choke stove?
I have a couple of those 68 restamps
look close yours has lines thru it and restamped 0097 close to the fender edge |
Oh I wasn't aware that they are restamed 0097. I need to look on edge side wall for number?
Oh I wasn't aware that they are restamed 0097. I need to look on edge side wall for number? My question I have is will it warm car up correctly on a ram.air 400 car? I might be overthinking again. I do that and get stick. Lol
One easy way to eyeball used covers right off is that the hole for the rod is CLOSE to the middle of engine on a 2bbl carb engine.
And on outside closest to valve cover on a V8. Lots are selling used 22bl choke covers as 4bbl.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
Have several dozen original 4 bbl choke boxs. The lined "restamped 8097" version was actually done so by Rochestor Products. Can't say I've seen such a line stamped choke stove on an automatic '70 application & have owned two original '70 YZ engines & examined several others.
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
Chock.stove
check........my earlier post
9098 restamped on yours n the picture not 0097 now that im looking on a monitor instead of my phone Last edited by Scott Thelander; 05-05-2022 at 03:22 PM. |
The Following User Says Thank You to Scott Thelander For This Useful Post: | ||
2bbl and 67. Had the lever coming out on the firewall side
68 up had the lever on the radiator side It also looks like there was 2 different covers for 67 The 3 67’s on the top row have a different slot where the rod enters. The lower 67 is like the 68up. No wiggle in the opening see the left one it shows up good And a 2bbl lower left for comparison with long rod |
Choke stove
Thanks you for pointing that out! I'm still a rookie and yes it's a 9098 I think I didn't notice that. I better hunt a 0097 and have a nice original. Thank you., either it got swapted out long ago or when I got original car beguile and got back a 1969 428 auto carb. I think it was 7029268. But thank got I found a 7040270
"check........my earlier post"
my above statement was meant to read updating my first post ,.... NOT for you to check my first post .... sorry for any confusion Scott |
Thanks for the pics Scott.!
Ok so I found a 0097 hopes it's correct for ra3 70 auto. I have my ames one too. When it arrives I'll show it and compare and maybe learn more. Thanks group
Thread Tools | |
Display Modes | |
