Old 05-16-2022, 05:22 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default ok here I go again
My current dilema is a new fuel pump,starter,wheel well solenoid ,oil pressure switch and relay for fuel pump. My starter continued to run after I shut it off.Could someone write out a schematic for this wiring.I hooked the ignition terminal from the pressure sw to the I term on the solenoid .The s term. on the p/s to the s term. on the solenoid.The p term on the p/s to the pump and relay.
Then a small yellow and white wire to the i or s terminals on the solenoid.Then lg red to the solenoid. Thank you for any help. Just remembered,I jumped terminals on starter to install solenoid.
Tim
