Old 09-01-2020, 04:43 PM
sdbob sdbob is offline
Default Rag joint question of material used to manufacturer
I was looking at an old early 70s rag joint. I was thinking could 1/2" conveyor belting be used to repair? Belting had what looked like same layering.Conveyor belting seems to last from what I've seen in construction. I was thinking punch holes carefully,cut diameter with a hole saw. I'm I innovative or crazy?
Old 09-01-2020, 04:58 PM
dataway's Avatar
dataway dataway is offline
Probably could ... there is another topic on this subject being discussed right now ... evidently Doorman makes a coupler with the right material. I'm unclear as to if you can buy just the disk or if you must buy the whole coupler.
Old 09-02-2020, 12:41 PM
1968GTO421's Avatar
Here's a link to the other rag joint discussion going on:
http://forums.maxperformanceinc.com/...d.php?t=843693
GTOAA--https://www.gtoaa.org/
Old 09-02-2020, 09:39 PM
Rincon Rincon is offline
Dorman carries several steering coupler assemblies. Only one pn#31000, is a steering coupler disc kit that includes just the rubber disc and the hardware.is that what your talking about?
Old 09-03-2020, 02:04 AM
dataway's Avatar
Which one of these kits would be the right one?
https://www.dormanproducts.com/gsear...pling+disk+kit
The 31002 looks most like my OEM parts.
Old 09-03-2020, 08:09 AM
P@blo's Avatar
P@blo P@blo is offline
Thanks Johnny you are a gentlemen as always.
Yes it is the Dorman 31002 kit here are some pictures of one I have in my parts bin. You can see the disc has the more correct layering. Not saying its original, but its the closest I have found to OE.
ID:	548575   Click image for larger version
The Following User Says Thank You to P@blo For This Useful Post:
Old 09-03-2020, 01:09 PM
dataway's Avatar
Thank you, I just ordered one.
Old 09-03-2020, 10:58 PM
Schurkey Schurkey is offline
While the application is entirely different, one of the best things I ever did to the steering of my '88 K1500 was to scrap the lower steering column shaft along with the rag joint, and install a steering column shaft that has a metal U-joint instead.
Rag joint failures on the '88--'98 pickups (and similar-chassis SUVs) are epidemic. It's common as dirt to have to herd them down the road by sawing the steering wheel left--right--left--right about "three inches" constantly. If one looks at the rag joint, the steel parts are polished by banging against each other because the "rag" is worn-out and has gone soft.
IF (big IF) there's a similar steering column shaft that dispenses with the rag joint in favor of a U-joint that fits your application..take that option!
