Old 02-01-2009, 06:40 PM
theYman's Avatar
theYman theYman is offline
Default Diveshaft is too long? M-20 explosion
I think I FINALLY figured out why I exploded my M-20 transmission last month. I originally posted that the front bearing retainer bolts had loosened up. BUT, I think they backed out AFTER the explosion. The case was split at every bolt hole.
Today I mocked up the driveshaft and I only have 1/2 inch of yoke slip with the tires on the ground. I believe this is way too tight..? When the trans exploded the car hooked up really well and squatted leaving a patch of rubber.
What do you think? How much slip should a driveshaft have? 1 inch?1.5?
Thanks,
Trent
Old 02-01-2009, 07:28 PM
Hurst65's Avatar
Hurst65 Hurst65 is offline
Hummm... 1/2" maybe a little tight..... 3/4" sounds about right.
1965 GTO, 408 tri-power, 4 speed, Currie 12 bolt w/3:42's, Hurst wheels
Old 02-01-2009, 09:48 PM
1qikta's Avatar
1qikta 1qikta is offline
You actually need 1 1/2" slip especially with a 4 speed. It will wrap up and get into a bind quickly. The pinion can move 3-4 degrees very easily with worn springs and isolators....sound like what happened.
By the way the 1 1/2" figure came from my driveshaft guy.
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
Old 02-01-2009, 09:59 PM
Hurst65's Avatar
1 1/2" sounds like a lot to me...
Old 02-01-2009, 10:05 PM
69Customs's Avatar
69Customs 69Customs is offline
Have to agree with 1qikta. With wheels on the ground it needs to be able to go in 3/4-1" when rear suspension is lifted up and when suspension lowers 3/4-1" out for a total of 1-1/2" or more. Saw it in an article about drive shaft lengths and measurements.
Old 02-01-2009, 10:10 PM
Hurst65's Avatar
since when do we take any kind of suspension measurements with the weight off the suspension???
Old 02-01-2009, 10:17 PM
lust4speed's Avatar
Compressing suspension will reduce clearance. If you want to find out for sure just take the rear springs out and jack the rearend up until it is against the stops. I set both 4-speed and auto driveshafts with 7/8" travel available (slide driveshaft in the tailshaft until it stops and pull out 7/8" and mark).
Mick Batson
Old 02-01-2009, 11:31 PM
theYman's Avatar
My driveshaft is 49.5 inches to u-joint centers and I have 1/2 inch slip.So I need a 48.5 inch shaft....I think...?
Old 02-02-2009, 02:38 PM
66Mutt 66Mutt is offline
Ymen,
I had a front bearing retainer get loose on an old Vette with Muncie in it. It did not grenade the transmission although I suppose it could. My threads were stripped out and the input shaft damn near rubbled a hole in the retainer. Needless to say oil leaked out the front retainer and soaked the clutch. Seems like you would have that warning sign before the thing blew up. So your other failure mode seems more likely to me.
Doug
Old 02-02-2009, 05:09 PM
theYman's Avatar
I found this place online and spoke with them. They have some good deals on used nascar shafts. http://www.musclemotorsports.com/dri...eel--used.html
and according to cirle track magazine....."The correct length driveshaft should have about 1.25-1.40 inches of possible forward movement before the slip-yoke contacts the tailshaft internally or its housing seal externally. Add or subtract from the known center-to-center length of the measuring shaft to determine the measurement that will best achieve this desired clearance. A typical stock car trailing arm suspension will cause the shaft to move forward 1/4-1/2 inch in normal use, yielding an actual running clearance of about one inch."
http://www.circletrack.com/drivetrai...fts/index.html
Trent
