Old 05-12-2003, 03:20 PM
Losdaddy13 Losdaddy13 is offline
Please forgive me but I don't know too much about carbs and vacuum hoses... but i have a '76 TA 400 4bbl 4spd and it appears that i cannot get the secondaries to open up at all. On the road, once i start to get on the gas, the engine starts to sputter. it was working fine a short time ago but a friend moved the vac hoses and now I just can't figure it out. Any help would be greatly appreciated!!!
carl
carl
carl
carl
Old 05-18-2003, 05:28 PM
Larry Navarro's Avatar
check to see if the top secondary air flaps can be pushed in with your finger.
years ago i had a q-jet that acted the same way. the culprit was a casting flash on the upper-inner rear portion of the secondary openings. this caused the top air flap to hang-up which in turn would not let them open under the engine vacuum once the lower secondary throttle blades opened. check first to see if this is the problem. if so, take the carb apart and use a small file and remove the casting flash as required.
1973 SD455 T/A
1979 S.E. T/A
http://community.webshots.com/album/16587603rOyvmFCiHs
Old 05-18-2003, 06:51 PM
carbking's Avatar
carbking carbking is offline
Adding to Larry's comment: check the choke and lockout mechanism to ascertain both are functioning properly. Note that if the choke plate does not obtain a vertical position the lockout prevents the airvalve from opening.
Jon.
Good carburetion is fuelish hot air.
Old 05-19-2003, 05:25 AM
will do guys, thanks for the help! i'll post back with any results.
carl
carl
Old 05-21-2003, 08:31 AM
Slow 75 TA Slow 75 TA is offline
Listen to Jon, he just helped me solve a similar issue with my 75 ta. Turned out, the choke was set incorrectly!
Old 05-21-2003, 09:50 AM
you know what guys?! from me fiddling around with the choke, i think i made it worse. now when the engine warms up the choke flap falls open and the rpm's go up to 'bout 2 grand (oops) . what's the proper procedure for properly adjusting a choke thats out of whack?
carl
carl
Old 05-22-2003, 01:40 PM
Advice offered to me by carbking on another forum:
Remove the air cleaner, and with the engine turned off; move the throttle linkage and the choke linkage and see what happens. The choke plate is connected to a 'secondary airvalve lockout' (this is a rocker assembly that prevents the secondary airvalve from opening). Move the choke plate such that the plate is vertical. Observe that the rocker assembly is pushed away from the airvalve and the airvalve will open. Observe that if the choke is not vertical, the airvalve will not open. If the choke is set too rich, more heat would need to be applied to the choke to cause the plate to obtain the vertical position.
The proper adjustment of the choke is that the choke mechanism should cause the choke plate to just touch closed at 68 degrees F. Assuming the spring has not been damaged by overtightening, this setting should allow the choke plate to obtain the vertical position, and allow the secondary airvalve to operate when the engine is warm.
Hope this helps you as much as it helped me! Thanks again, Jon!
Old 05-22-2003, 06:18 PM
carbking's Avatar
Slow 75 TA - you are welcome, glad to help.
Jon.
