Old 05-17-2003, 02:56 AM
budthespud42 budthespud42 is offline
Can someone out there send me a pic of the hood seal for a 74-75 Formula 400. I'm restoring a 74 and I bought a aftermarket seal and there is no diagram on how it goes on. I have to glue it in some places and I can't remember how it looked before I took the old one off. Thanks!!
There's nothing like the sound of a well tuned 400cid 74 Ram Air Formula
Old 05-17-2003, 07:56 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Are you referring to the seal that mounts on the cowl and seals the hood and cowl together?
1971 Trans Am 455 HO - Cameo white
1973 Trans Am 455 - Buccaneer red
1984 Trans Am 305 - Royal blue
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 05-23-2003, 07:12 PM
Yeah along the top of the firewall, in front of the window.
Old 05-28-2003, 08:12 AM
Slow 75 TA Slow 75 TA is offline
Why do you have to glue it? There should be a bunch of clips in the bottom of the seal, and they go into holes on the cowl. I will try and find the instructions that came with mine. It sounds like you need to order the fisher body manual for 1975. That will help a lot.
Old 05-28-2003, 09:30 AM
form74's Avatar
form74 form74 is offline
Does it look like the one in this add. If not you might of gotten the wrong one. I bought one that had 70-81 on it at a swap meet, went out and looked at my car and went back in and returned it.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2417241810
http://www.pontiaconline.com/members/117/
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 06-01-2003, 04:11 AM
Thanks for the help I think I got it figured out now. Its held on with clips but I did use some glue to hold it in some spots.
