Old 04-19-2003, 02:25 PM
Huebner Huebner is offline
My 1974 Formula 400 has aftermarket oil pressure gauge and tempature gauge and want to get original ones of a junked car. Witch years use the same gauges and where the gauges the same used on Firebird and Trans Am? Whould be great if anyone hade som picture of them so I can get the right ones.
Thanks again.
Owner of a 1974 Formula in Sweden!
Owner of a 1974 Formula 400 in Angelholm, (70 km north of Malmo) Sweden!
Thanks again.
Old 04-27-2003, 10:00 AM
I took a picture of the gauges today. These can't be the original ones.
But does anyone owning a 1974 Formula whit automatic transmission have any picture whit stock gauges?
Will be grateful for any help!
Owner of a 1974 Formula 400 in Ängelholm, Sweden!
Old 05-08-2003, 10:23 AM
242679goat 242679goat is offline
My 74 Firebird Formula 400 with th-400 auto, has a fuel and volts gage located where your Formula has the temp & pressure gage. My temp & pressure gage is located between the speedometer & tachometer in a single round pod with the oil pressure gage on top & the water temp gage on the bottom. Also my F-B is equipted with the optional rally gage package that was standard on the Trans-Am.
Old 05-08-2003, 02:58 PM
Mr. T/A's Avatar
Mr. T/A Mr. T/A is offline
You do not have the rally gage package. If you did, you would have a dash that looks like the pictures I sent you. Easy to change if you want. Just look on Ebay.
Crusin in the Great White North!
Old 05-09-2003, 12:30 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Mr. T/A:
Crusin in the Great White North!<HR></BLOCKQUOTE>
Hey man! Where are the picturs? I'v checked my e-mail several times allready! Try to send them again!
Old 05-11-2003, 09:07 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by 242679goat:
My 74 Firebird Formula 400 with th-400 auto, has a fuel and volts gage located where your Formula has the temp & pressure gage. My temp & pressure gage is located between the speedometer & tachometer in a single round pod with the oil pressure gage on top & the water temp gage on the bottom. Also my F-B is equipted with the optional rally gage package that was standard on the Trans-Am.<HR></BLOCKQUOTE>
My car is NOT equipped whit a tachometer but a clock with three warning lights for oil, water (temp) and amps sits in its place as you can se in the picture. In betwin speedodomder sits the fuelgage. Is this correct?
Old 05-11-2003, 05:26 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Thats correct for a car not equipped with auxiliary gauges. Someone added the temp and oil press gauges to your car. Originally there was not even a hole there.
In order to add factory style oil press/water temp, Amp, and fuel gauges like in the auxiliary gauge package you'll need to replace the entire dash and engine harness and engine sensors. Its not a simple task.
1971 Trans Am 455 HO - Cameo white
1973 Trans Am 455 - Buccaneer red
1984 Trans Am 305 - Royal blue
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
