Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 08-02-2023, 03:11 PM
Joe-Touring Joe-Touring is offline
Default #17 Cylinder Heads bare F/S
Bare Pontiac heads off a 1968 350. Small valve heads, pressed rocker studs. Chambers measure ~83 cc’s. Should be great for a 400 build at 9.5:1 comp ratio. Was going to use these for a 400 build but went in a different direction. $50 plus shipping. Located in western WA.
67 LeMans, 326, M20, 3.31 12 Bolt
Old 08-02-2023, 05:11 PM
Dragncar Dragncar is offline
I think Jim Robertson was looking for some of these. Might have been 15s ?
Old 08-02-2023, 06:51 PM
Jim is looking for the elusive #18 1968 350 HO head.
Old 08-02-2023, 07:35 PM
BILL BOWMAN1's Avatar
Sorry to hijack, but what makes these so desirable?
Old 08-02-2023, 07:39 PM
When you want to build a correct engine you need the correct casting # heads, when’s the last time you saw a 1968 350 HO ?
In 1969 the 350 HO shared the same #48 casting as the RAIII and manual trans 400 engines, the 1968 350 HO had its own specific head casting.
Likely the biggest and only difference between the #18 HO head and the #17 would have been combustion chamber volumes, the #18 surely had a smaller chamber for a higher compression ratio. Both heads have small 1.96”/1.66” valves and press-in rocker studs.
Jim has his reasons and that’s enough.
Old 08-02-2023, 07:50 PM
I suppose another way to look at it, if you really wanna build an iron headed 350, the #18 heads have a tight 66cc chamber and small valves. Tight chamber to get your CR up and smol valves to avoid shrouding. Not many open chamber Poncho heads fit that bill.
Old 08-03-2023, 12:23 AM
Old 08-03-2023, 12:46 AM
Couple things I forgot to mention:
Casting flash has been removed and the pushrod openings have been elongated for 1.65 rockers.
The valve guides are knurled, if that's important to you.
Old 08-15-2023, 02:38 PM
Price reduced, I’m just trying to get these to someone who’s gonna use em. Free local pickup, or whatever shipping is.
Old 08-24-2023, 01:20 PM
Bump
Old 08-24-2023, 06:57 PM
unruhjonny's Avatar
if I was passing anywhere near you I'd snap those up - but I have already been to Washington this year...
I sure hope these find a good home...
1970 Formula 400
Old 09-04-2023, 03:58 PM
Looks like you’re up in Calgary, quite a drive. I’ve got some family up in Drumheller.
Yeah, hope someone can use em, they’re in pretty good shape and you’d get fresh seats when you step up to big valves.
I was thrilled to find em, but the cyl head guy at my machine shop quit. He originally quoted me at $1200 labor to set em up, got some new quotes and they were all around $2200. Decided at that price it’d be worth it to just snag some KRE d ports.
Old 09-04-2023, 08:10 PM
unruhjonny's Avatar
Yeah, I totally get it.
I have a second cousin who lives in Portland, and I pass through Washington state to go to his place - my route is wholly determined by where I want to stop.
1970 Formula 400
Old 09-27-2023, 03:35 PM
Bump
Old 10-12-2023, 04:26 PM
Bump
Old 10-25-2023, 10:19 PM
mach flyer mach flyer is offline
Hey Joe;
I think I might be interested in those heads … what would the shipping cost be to area code 72704 ??
Andy
Old 03-30-2024, 02:47 PM
Bump
