Old 10-30-2023, 04:45 PM
racerboy's Avatar
racerboy racerboy is offline
Default ‘70 TA alternator install
I picked up an rebuilt open-faced alternator over the summer and finally got around to trying to install it this weekend. Granted, my 400 RA3 engine is out for a stroker build and am currently running a ‘69 428, but it has all the correct brackets from my ‘70. When I first tried to install it, the bolt ‘ears’ were 180 degrees off, so I clocked it 180 degrees. Then I noticed that the rear bracket (attached to water neck and first manifold bolt) would not line up with the threaded hole in the back. I clocked it another 90 degrees, but now the plug is on the side, not the top, and I don’t think it’s correct.
Interestingly, the ‘70 Firebird Supplement has a drawing of the alternating that looks just like mine, but I don’t see how to attach the rear bolt with the plug on top of alternator.
Here is the shot of the rear of the alternator (one on left is open-faced)
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 10-30-2023, 05:25 PM
That’s a early 69 rear case
Old 10-30-2023, 06:37 PM
Formulabruce's Avatar
Clock the rear up to 12 O'clock so connector is up top.
This is a 70...
Old 10-30-2023, 07:22 PM
68bird400HO's Avatar
Agree with Telly, you have a 69 rear case. The bolt hole on a 70 rear case is in the same location as the one on the right. Also, the one on the right looks to be clocked correctly.
Old 10-31-2023, 10:34 AM
Here’s the one you need
Old 10-31-2023, 08:52 PM
racerboy's Avatar
Thanks Telly. I sent you a PM.
Old 10-31-2023, 11:44 PM
Ramairnacho Ramairnacho is offline
Default 1970 back
You got the 69 version. Remember 69 trans am alternator is expensive and I imagine so are the backs. You can sell yours,use it, trade ect. I have a 902 with the 71 style back with correct mounting bolt is another option for you
ID:	622651   Click image for larger version
Old 10-31-2023, 11:53 PM
Default More pics that can help
These are the 70 style only difference I see is the mounting hole is located at 3 o'clock vs 6 o'clock. I learned this stuff hunting down a mystery 1100904 that probably never existed and decided to build 1.
ID:	622653   Click image for larger version
Old 10-31-2023, 11:59 PM
Default More pics that may help
Hear is a service replacement I got and I believe it's correct other than pulley and fan color. Hope my pics helped. I chased down a 1100904 and to this day have never seen one. I was also told that the diamond correct backs aren't that good either and burn out easy and the 71 and new style is better. I'll know more once I start building her up. I'm no expert just trying to.help.
ID:	622655   Click image for larger version
Old 11-01-2023, 12:41 AM
Default A 1969 alternator
Here is some pics of an original 69 open face pontiac trans am alternator. This will probably help you I hope.
ID:	622657   Click image for larger version
ID:	622658   Click image for larger version
Old 11-13-2023, 04:36 PM
racerboy's Avatar
Thank you! Had a family emergency the last couple of weeks so am just getting back to this issue.
Old 11-13-2023, 04:38 PM
racerboy's Avatar
Thanks for the photos and explanation!
The Following User Says Thank You to racerboy For This Useful Post:
