Hi, I"m putting a posi unit in my 60 Catalina and would like to install new carrier bearings and gasket, where can i find the bearings and gasket for my project. Thanks
brad duerst at a company called fabcraft will have everything that you need in a kit. New crush sleve also.....They are on the web...
http://kurtspontiac.homestead.com/Pre1964Pontiacs.html |
61man could you provide the web address? I just did a search on Fabcraft and found a lot of snowmobile related stuff.
Any help would be great as I am going to need to replace a center carrier bearing myself. |
I don't find his web site either but his number is 1 800 208 8242, hope this helps
Frog: I deal with Brad all the time. The man is a wealth of knowledge on early rears. I am sure Brad can fix you up but you should be able to get them from NAPA. I get all my bearing & Diff gaskets from NAPA. They generally have to order them but available.
Gasket # is A Victor # P-29325 I don't have carrier brs/race numbers handy but should not be a problem to look up. If you need numbers I could get them.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
