Old 10-04-2021, 10:28 AM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Default Mini Starter
Good Morning everyone, we went to install the new full size AC Delco starter on the 1979 W72 Trans Am that we just put the 467 in, and found that the factory sized AC Delco starter will not fit between the Hooker Super Comp header and engine to install it, so we ordered a Powermaster XS 9510 for it last night. I watched a few videos on YouTube, and one guy shows that he had to cut the factory 4-speed Inspection cover(dust cover), so that the mounting block on his new mini starter would mount properly, but he was using the IMI-108 starter, not the Powermaster 9510, and it was not a Trans Am, I believe it was a 67 GTO. Is it common practice to have to cut that cover when installing a mini starter? To better show what I'm taking about, here a a few pictures of what I'm talking about.
ID:	574386   Click image for larger version
ID:	574387   Click image for larger version
1978 Trans Am
Pump Gas 461 Stroker
Old 10-04-2021, 10:37 AM
Cardo's Avatar
Cardo Cardo is offline
I've installed the IMI on one of my cars and did not cut that cover. Didn't need to.
"I know just enough to keep me here, but not enough to get me out"
The Following User Says Thank You to Cardo For This Useful Post:
Old 10-04-2021, 11:27 AM
steve25 steve25 is offline
I don't think there's any down side to having to do that and in fact there is a plus side in that checking for the needed gear mesh with the needed big paper clip is now easy!
Old 10-04-2021, 11:43 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
should NOT need to cut anything!! GTO-Firebird or T1000.....it either fits correctly or it will fit perfectly back in the box! I do not recall which mini starter I used but it was a bolt in. REALLY more interested in that the big 100 lb gm unit would not go in thru the headers. I know it's tight but "can't?" that sux. ...can you use a BIG oil filter (ph25) or did you have to go down to the smaller ph3506?
The Following User Says Thank You to 67Fbird For This Useful Post:
Old 10-04-2021, 12:17 PM
Chris65LeMans's Avatar
I used the IMI, too. Didn't cut anything.
The Following User Says Thank You to Chris65LeMans For This Useful Post:
Old 10-04-2021, 12:18 PM
Yep, we tried it from every angle possible, the big starter was a no go. For the oil filter, we are using Wix 51045, it is 4.828" long and 2.921" in diameter, which I believe is smaller in diameter, but longer than the PH25. Thanks for the help
1978 Trans Am
Old 10-04-2021, 02:15 PM
Don 79 TA Don 79 TA is offline
i just put in the 9410 starter
all i had to do was take the shims off it and reclock it for the Dougs headers, as i am using a manual trans flywheel, seemed like it was set for auto flywheel is my guess
i really like this starter
i've used IMI's and have had some bad luck with them
i did like how the IMI was very clockable
i think the 9510 is the faster spin version of the 9410 ????? they had one model for 14:1 comp, and the other was supposedly a faster spinning one (mentioned for meth/alcohol)
they make a lot of them
the 9410 sounds like its stronger when cranking, but the IMI seemed like it spun it faster
not a big deal, both worked with locked timing and have clearance, but the IMI (hitachi style) is smaller compared to the Denso powermaster one
powermaster makes quiet a few starter models, so i may have it messed up model wise
the 9410 was supposed to be one of the strongest ones and rated for 18:1
i needed to replace the IMI one, which was their second strongest version as i though i broke ring gear teeth, but just the starter went
it would make one slight attempt to crank then sounded like it was either stripped teeth or a locked up engine
bench test confirmed this, plus i did check the flywheel all around too
it was making some weird noises
shimming the IMI (as with any starter) is CRUCIAL, it will F things up quickly
i did not have to cut the inspection pan either
The Following User Says Thank You to Don 79 TA For This Useful Post:
Old 10-04-2021, 04:24 PM
Mike Fowke Mike Fowke is offline
It may be a moot point now, but can you loosen the header and rock it outboard enough to slip the factory starter in? This is what I had to do on my '78 TA with a Canton pan and Dougs before I got a mini. The RobbMc doesn't require cutting the inspection cover.
The Following User Says Thank You to Mike Fowke For This Useful Post:
Old 10-04-2021, 06:03 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
D port or round port Hookers? I think on my round ports I could use a stock style but did have to loosen headers, went to a Tildon. Then one of my Canton pans had a bung there that stuck out and welded it flush.
Skip Fix
Old 10-04-2021, 08:36 PM
Doug Doug is offline
Smile CUT IT?
I did! Left enough of a tab where your index finger is pointing to latch up between block and bellhousing.
The Following User Says Thank You to Doug For This Useful Post:
Old 10-04-2021, 09:08 PM
Skip, these are the D-Port Hooker Super Comp, they are a couple decades old atleast I would say, maybe even older than that.... so the newer Hooker Super Comp may have possibly been resigned since....
1978 Trans Am
Old 10-05-2021, 08:49 AM
Thanks everyone, we will install the starter, check the mesh, remove it, reinstall the cover, and then reinstall the starter. This will keep us from having to cut anything. Appreciate the help
1978 Trans Am
Old 10-07-2021, 12:46 AM
We got the starter installed today, it ended up bolting right on there right out of the box, didn't even need any shims, and was already clocked correctly. It sounds and works perfect. Before final installation, we did remove the two small torx screws for the Infi-Clock on the Powermaster XS 9510, and reinstalled them with a little blue thread locker. There was no need to cut that inspection plate on ours either.... finally got the new 467 broke in, it seemed to go well so far. I appreciate yalls help.
1978 Trans Am
Old 10-07-2021, 12:55 AM
turbo69bird's Avatar
I got mine from a guy In Jersey one eBay fit well like an IMI
But much much less money.
Had other minis that wouldn’t fit even though they were labeled Pontiac. Couldn’t clock them to the right position
If someone needs the info on the seller I can look it up
960 HP @ 11 psi, 9.70 at 146.
The Following User Says Thank You to turbo69bird For This Useful Post:
