I just got the motor back in my Lemans, started it up and it won't shut off.
I'm 99% sure I got the starter connected right. Yellow wire on the inside terminal and purple on the outside terminal. If I disconnect the yellow wire, everything seems to work fine. Any ideas? |
purple wire should connect to the "s" terminal. if it's right them make sure the other wire is NOT hot with the key on. if it is this is the problem. this wire feeds 12volts to the coil while starting only. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
