Old 04-22-2002, 11:34 PM
TTS's Avatar
TTS TTS is offline
I would like to retain my console and factory shifter appearance. I have thought about a 68'His/Hers shifter. Will it install without many problems into a 72'?
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Right and wrong doesn't need facts all the time.
-Lighthouseman ("lawyer")
Starnes Performance Automatics
www.Starnesperformance.com
TTS's Avatar
TTS TTS is offline
Old 04-23-2002, 12:06 AM
A455GTO A455GTO is offline
I put one in my 70 GTO, I'm pretty sure 72 console will work also.
Check it out: http://community.webshots.com/album/36268723PMlriP
So many toys, so little time
'06 GTO, '68 LeMans project, bikes, etc.
Old 04-23-2002, 09:29 AM
HANDSEL HANDSEL is offline
I have a 72 with a console and A 68 dual gate shifter it bolts up fine ,But I haven't been able to get my car into low 1 or 2 I think. I can't remember which one is the last gear from drive. I haven't been able to work all the bugs out of my car yet. I heard that you can get the 68 GTO dualgate shifter cable from the Pontiac dealer. I went and got one but I think it's too short or something. I have yet to fix that! I looks great and everybody that sees it really likes it. They always say WOW!!! a Dualgate shifter cool! OH and ShiftWorks will have all the stuff you need also. Give them a call. I think they have a website also.
[ April 23, 2002, 09:30 AM: Message edited by: HANDSEL ]
Old 04-26-2002, 07:28 PM
Rob Tapp Rob Tapp is offline
The 68 his/hers shifter was used on the th400. If your 72 has the th350, the bracket will not bolt correctly to the transmission and will likely cause problems getting it to shift into the lower gears.
Old 04-29-2002, 12:13 PM
I do have a th400 But I can't get the shifter into the lower gears. Do you think I have the wrong bracket that bolts to the trans? I think I am using the wrong one. It's the one that came with the trans (baught used). The trans is from a 73 Buick. I will have to check out the GTO assembly book and give Shiftworks a call.
