SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 09-13-2023, 08:16 AM
421 Bird's Avatar
421 Bird 421 Bird is offline
Default Pontiac 453 race motor
The motor is a 1965 421 four bolt main. It was assembled by Kauffman and dynoed at 662 hp with a 950 carb. I added a vacuum pump and 1150 Dominator carb, which probably brought the HP to 700. The motor runs great and recorded a best of 10.10 in the 1/4 mile in a 3,450lb car(without the driver). The motor will only need a vacuum pump and carb. I have a DUI distributor that was on the motor that will be included.
421 block bored to 4.121
4.25 Stoke Eagle forged crank
6.800 Eagle 3D H Beam rods
DSS forged pistons
Comp Cams roller R9+4 275/284 duration .740/.690 lift
Crower 66260 roller lifters
1.50 Scorpion roller rockers
Kauffman 56cc 380cfm High Port heads
Kauffman Northwind intake port matched to heads
Meziere electric water pump
Moroso 7 qt oil pan
Performance Quotient flexplate
The intake has a 4150 bolt pattern. I have an HVH 2" spacer/adapter that I will include with the motor. I will post the dyno sheet. $8,500
ID:	619924   Click image for larger version
ID:	619925   Click image for larger version
The Following User Says Thank You to 421 Bird For This Useful Post:
Old 09-13-2023, 08:41 AM
421 Bird's Avatar
Here is the dyno sheet.
Old 09-13-2023, 12:07 PM
slowbird's Avatar
slowbird slowbird is offline
Compression?
Old 09-13-2023, 01:04 PM
421 Bird's Avatar
Compression is 14:1
Joe
Old 09-13-2023, 09:28 PM
beemergary's Avatar
I just need a 421 assembled block. Good luck
Old 09-19-2023, 07:18 PM
Deathwishracing's Avatar
Deathwishracing Deathwishracing is offline
I’ve got a 71 round port 455 with about 1000 miles on it in my convertible any interest in a trade
Old 09-20-2023, 12:27 PM
421 Bird's Avatar
Thanks for the offer, but I am looking to sell the motor.
Old 11-03-2023, 12:04 PM
15bhardwick 15bhardwick is offline
How many passes does the engine have on it?
Old 11-04-2023, 08:49 AM
421 Bird's Avatar
I don't have all of the passes logged, but I would say there are 40-50 passes on the motor. The last time made a pass was at the Pontiac Nationals this year.
Old 11-18-2023, 11:10 PM
Adecco Adecco is offline
Still available
Old 11-19-2023, 08:53 AM
421 Bird's Avatar
Yes, it is still available.
Old 11-19-2023, 10:43 AM
61-63's Avatar
61-63 61-63 is offline
So the motor went 10.10 in the quarter mile without the driver? Just kidding but that sentence could be read that way. Beautiful engine and it has all of the right stuff in it.
Old 11-20-2023, 10:05 PM
421 Bird's Avatar
Yes, it could read that way. Lol. I should have said 3,675 lbs with the driver.
Old 11-23-2023, 08:42 PM
slowbird's Avatar
How does the starter bolt on?
Old 11-23-2023, 09:56 PM
421 Bird's Avatar
I used a Powermaster XS mini starter with no issues.
Old 12-12-2023, 04:32 PM
10.10 is a stick car or auto and if auto what stall, rear gear and foot brake or trans brake...
Old 12-12-2023, 05:18 PM
421 Bird's Avatar
The car was an automatic with a 4,000 rpm stall converter. Rear gear was 4.11 and car was foot braked. Here is a link to the car the motor was in:
https://forums.maxperformanceinc.com...d.php?t=866641
Thanks,
Joe
Old 12-28-2023, 03:10 PM
421 Bird's Avatar
The motor is sold.
Thank you,
Joe
