Well, I guess if your patient enough, you find stuff. I was able to pick up a fairly complete 1970 455 HO engine this weekend. It has been in a shed in Michigan since the early eighties, not stored great but at least inside. Good news is it’s a WA block, 64 heads, pretty complete less carb and front accessories. It even came with a bell housing, clutch, pressure plate, starter, motor mounts etc. Story goes it was pulled out a wrecked 70 GTO and was going to be swapped in a Firebird, but it never happened. The usual someone didn’t pay somebody or whatever, and the motor sat and no one ever came for it.
So, the property owner decides to clean out the shed, a friend tells him this motor might be worth something so he posts it on FB marketplace. I see ad, am only 25 minutes away and am the first guy to get there. I pay him the $600 he’s asking for it, try to negotiate a little but not too much ands it’s mine. Got it home yesterday.....it seems pretty original, never opened up and has all the little brackets and clips that we always search for. The engine is stuck, but I’ll try some sea foam or some oil down the spark plug holes for a few weeks before I seriously try to rotate it. I’m happy.......winter project ahead. I’ve read hundreds of 455 build posts on this forum, I’m sure I’ll be back for advice once I get it torn down. |
Pick up a can of “aero kroil” and soak those pistons. Best penetrating oil out there ( commercially available)
GOD does business with people that mean business! |
Nice
.................................................. .No One Ever Escaped Tyranny By Compliance.............................. |
Nice Score! Looking forward to the build.
Nice find. A friend had a 70 455 ho 4spd red car.I believe he still has it,he moved to Florida when he retired.He put a holly carb on it,back in mid 70s and I ended up with the carb. I traded the carb to a guy in Indiana for TA oarts.
You got that right ! I have a few ideas but I’ll wait until I get it apart to see what I’m working with.
I like it nice find.
Acetone and ATF 50/50 makes a great penetrating oil. I would get it on a engine stand, with a bank up level and squirt in enough to cover the tops of the pistons so they can soak the rings for a day then do the other bank. After that, try rocking the flywheel back and forth until it get moving.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
Nice find !! Worth every bit of that 600.00. Too bad the carb is gone. Should have the 068 S cam if it hasnt been replaced. My car still had the 068 cam in it when i bought it.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
I have the correct 70 HO 4 speed carb here if you need it.
Shawn 1971 Formula #s match white/tan 1973 TA Brewster/white #s match 1972 Buick GS455 #s match 69k miles now a 470 stroker. 1986 Buick Ttype 66K miles many mods 10 sec street car. 2001 Mustang gt premium vert. Mamas car |
That is an awesome find, especially these days!! I’ve done two engines that were rusted stuck. The 1st we soaked in oil and beat and banged and cranked which didn’t turn out so well. The 2nd we soaked and then used a hand held sand blaster to clean around the rings as best we could. Then used a torch to heat and cool things a few times. That way worked much better lol. Congratulations!!
Great find! I think i'd pull the heads and start with some diesel fuel soaking in around the piston/rings and go from there.
Using a scope would help determine if it's got a shot of spinning, as is, or not. If .one cylinder wall has much corrosion, the heads need to come off, for more serious work.
The ATF and acetone, I have heard of here, another I recently heard of, is ATF and diesel....
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
![]() Quote:
I agree that's an awesome find!
![]() What's the date code on the block? The partial VIN on it? ![]()
![]() Quote:
I’ll get the partial vin once I clean all the crud off of it Several other members have asked for date codes, I’ll try to post them all at once when I have them |
SR carb or a 69' built one?
![]() Quote:
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
K249 fits the EUN.
So long, farewell. |
Nice score! I once owned a 70 GTO 455 4 speed car. Vedoro green on green.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge Last edited by SRR; 09-03-2019 at 02:09 PM. |
Thread Tools | |
Display Modes | |
