Is it possible to remove the clock on a '68 GTO from behind the dash, or does the face of the dash and instrument panel have to be disasembled somehow? This car has A/C and I've removed the ducts under the dash many times, but I wouldn't know how to take the dash apart. I have the GTO Restoration Guide, but that doesn't seem to explain removing/reinstalling a clock.
Also, if I can get the clock out, what recommendations are there for getting it repaired? I would like to keep the original movement and method of operation. I'm the original owner of this car and it's mostly original, including the paint. Thanks! |
HI,
The 68 GTO clock comes out from the rear of the dash. It is a close squeeze, but it will come out. The clock used an electro magnet to wind the clock. A set of points come togehter, energize the electro magnet causing it to turn. Most that I have found have the windings of the electro magnet byrned out and the plastic melted because the points stuck together. You can buy a quartz kit to fix your clock or you can send it off to have it repaired. By the way, the faceplate for a 68 GTO clock is a different color than a 69 or 70 GTO. I put a in-dash tach in its place in mine The cost was the same as getting mine restored with quartz movement. Good luck, Mike 1968 Pontiac GTO 400CID, 350HP, 4-Speed Manual, 3.55 rear. Aquamarine Blue exterior, 219 Blue interior. Chrome bumper, AM & 8-Track
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels |
Welcome to PY, Larry can you post any photos of your 68, Ask any ?s here that you need, Good luck and have fun.
Cuz68 |
I've "repaired" these clocks before. Repair came in the form of spraying lubricant on the works and voila--they work. I'd recommend a good silicon lubricant like you put in your door lock--not graphite. The clocks work by a winding mechanism. They load the spring by the electric circuit. When the points close making contact, a lever throws an arm back that winds the clock and it begins to count down until the points close again and the process starts over. Over time the works clog up and the points can stick and burn. I've simply cleaned them and they're fine. If your car isn't driven often, I'd recommend going the quartz replacement cause it will run a battery down and you have to reset the clock if you disconnect the battery.
Doug ----------------------------- [This message was edited by PonchoV8] www.geocities.com/yqtnxnb |
Here is a picture of the back side of a 1969 Rally Clock.It has the brackets very simlar to the '68 style.You will probaly have to remove the radio and some of the A/C vent to reach up behind the dash to remove the clock.
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
GTO.....Gran Turismo Omologato,True Pontiac Excitement! |
Pulling the front seats can be a big help when working under the dash. When you remove the clock.
--------------------------------------------------------- "GTO? "Get Tools Out!!!" ---------------------------------------------------------
--------------------------------------------------------- "And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor?? --------------------------------------------------------- |
...if you happen to be over 190 lbs or 6'.
Both, LOL!
Poncho V8, I am going to try the silicone lubricant on my clock. I appreciate the suggestion.
Thanks, MaxWT (68 GTO) |
