is there any way to increase the idle circuit on a holley 600cfm vacuum sec carb? i had to drill 1/8" holes in both primary throttle blades to get it to idle without dripping from the nozzles on my 455. it also would pull too much vaccume on the vaccume advance(about 10 inches out of 15 at idle)
BTW, i don't have money for a bigger carb or to send it out, so thats not an option. thanks.
______________________________ 1980 Special Edition Trans Am 1975 2 bolt 455, 6X-8 heads, summit 2802 cam, stock intake, edelbrock 600cfm. TH350 trans and converter out of a 78 TA, 10 bolt posi rear with 3.42 gears, 225/70-15 tires. |
Is the carb equipped replaceable air bleeds? They look like little jets that screw onto the top of the main body just behind the metering block and can be seen w/out taking anything apart on the carb. Some are the pressed in type, tese type I have never messed with, but the screw in type can be calibrated like regular jets. Maybe these need adjusting to allow more air to mix with the fuel at idle so that you don't have to crank up the idle screw too much and transition from idle circut to main circut causing the carb to dump access fuel also, or possibly the accel. pump need to be adj.
