Old 10-09-2004, 08:11 PM
riv80 riv80 is offline
I have noted references to shoulder harness as an option for a 67 GTO HT. Does anyone know if the bracket or whatever is necessary was installed on all HTs. Has anyone installed a three point SB/SH in a Ht? Thanks
jim
jim
Old 10-10-2004, 04:30 AM
Shadowjack Shadowjack is offline
Can't find the reference, but I seem to remember that they were a mid-year addition to '67. It's a change in the structure of the top bracing over the quarter window--impossible to add later.
The early shoulder harnesses were kluges--there were two buckles. You would have to modify the inner quarter structure to get a later-design self-retracting three-point belt setup on there--and the belt would always be hanging there.
Old 10-10-2004, 09:12 AM
Thanks for the info. Is there any way to tell if its there without getting into the headliner?
thanks
Old 10-10-2004, 05:13 PM
This is mine. Picture 1 shows where I measured from.
Old 10-10-2004, 05:14 PM
Picture 2 is the measurement.
Old 10-10-2004, 05:21 PM
hocodave hocodave is offline
I'm sitting here reading Zazarine's 2nd edition Pontiac GTO Restoration Guide. Page 166 says that as of Feb 1 1966 all bodies were built incorporating anchorage provisions for the front seat belt straps.
Anyway, the reason I know this page is because I too wanted to install shoulder belts. This page led (leads) me to believe that all 1967 GTO HT's had this provision.
As I recall, I ran a finger against my headliner and I eventually felt two holes that felt like they were correct. I must admit I was a bit apprehensive when I punched a hole in my headliner, but there they were (two on each side, within a few inches in front of the coathook).
Next task was to find the actual shoulder belts. I didn't see any reproductions, but after some hunting I did find some at Carlise. Actually, I was really lucky to find shoulder belts that also still had the little bolts attached for proper installation.
Hope that helps. Good luck.
