When the headlights close on my 95 Firebird they make a grinding sound for app. 7 seconds then it quits. Is there an adjustment to the lights ora relay that is bad?
I read somewhere that there are plastic gears that go bad and it will start making that noise.
check out this place for replacement. http://www.rodneydickman.com/n113.html |
Thank-you for the information.
For a quick fix, albeit temporary, You can disconect the linkage from the motor, spin the motor 180*, then reattach linkage. This uses the opposite side of the gear where the travel stops which is what wears out the gear.
I did this in '99 on mine and so far so good. Its no longer a daily driver but it does get used (and slightly abused, no trailor queen here). I also pull the rubber covers off the manual knobs and spray some lube in the motors occasionally.
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
I had the same thing happen to my 95 T/A. I took the motor apart and turn the gear and put it all back together. Never had another problem with it.
