Old 04-14-2004, 09:54 PM
FantomPoncho's Avatar
FantomPoncho FantomPoncho is offline
Let me give all of you some background on my problem, then I'd like some suggestions. If you say I need to yank the motor, THEN I'll blow my brains out...Here goes...
Went out one morning to fire up my '78 T/A and nothing happened. The carb had been running crappy for a long time, so I figured it was time to get a new one. I get one ordered. While waiting for the carb, I figure it's a good time to fix the water leak around the timing cover.
I proceed to fix the leak.
Upon putting the balancer bolt back on, I notice something strange. It was not a 15/16 bolt (actually I noticed it when taking it off, but just shrugged it off). Went to torque to 160 ft/lbs and it slipped at around 100. Pulled the bolt out and the threads were galled on the bolt.
To make a long story short, the bolt was very odd size of 18mm fine thread. I figure some lazy mechanic in the '80s stripped the threads and this was the next tap size. It took me a week to find a replacement bolt. It worked and the balancer torqued to 160. Yeah!!! - Not so fast...there's more.
My carb comes, I bolt it on, and the car won't fire. After compression checks and some troubleshooting, the cam is bad. So I proceed to fix this problem. Get the replacement cam in, test compression on all cylinders and they are right on. Put the front of the motor back on, go to torque the only metric hunk 'o metal on this car and...doh! No dice. This time the bolt slips again.
I haven't verified this, but I'm pretty sure the threads in the crank are galled.
Anyone dealt with this before? Is there a way to fix the threads without yankin the motor?
Help!!!
Help!!!
Old 04-14-2004, 10:01 PM
Z Code 400 Z Code 400 is offline
I have fixed a number of cranks with a Heli-Coil Thread Repair Insert. No need to pull the crank as long as you can get a drill in there. I have used a 90°drill with great success...Robert
Old 04-14-2004, 10:24 PM
I've thought about the thread repair idea. Is there a thread repair kit for an 18mm fine thread? I found that even specialty bolt places don't even stock that size bolt, let alone a thread repair kit.
Old 04-14-2004, 10:29 PM
cioccoj cioccoj is offline
If your going with a helicoil you don't need an 18mm. Use something american thats close. Your going to drill, tap and install a coil anyway.
Old 04-14-2004, 10:35 PM
72firechicken 72firechicken is offline
I too have also repaired theards in cranks with the heli-coil kits and they have worked great also I have not had any problem getting odd size crank bolts from my local fastner supply.
Old 04-15-2004, 05:48 AM
72Firechicken, I'll be looking for a thread repair kit and give that a shot. For kicks and giggles, call around your local fastener shops and ask for a M18 x 1.5mm grade 8 bolt in any length. I'll bet you'll get plenty laughs and jeers. I ended up getting my bolts shipped from a place in Maryland. BTW, I live in AZ.
I even called ARP and they laughed. I started combing the import dealers, bus and semi-truck repair places. I found ONE place with ONE bolt, but it wasn't grade 8.
I hope finding a thread repair kit won't be nearly as hard.
Old 04-15-2004, 08:00 AM
mc69ta mc69ta is offline
Hello
If you use a heli-coil kit to repair the crank
get the stock crank bolt and the kit to match it
Good luck
Mike
Old 04-15-2004, 08:41 AM
79firebird_99TA's Avatar
79firebird_99TA 79firebird_99TA is offline
Whatever you do, don't blow yer brains out! That might mean that you'll never get that Pontiac repaired and back on the road!
79 Firebird/`70 400 with `77 6x-4s shaved .065"/4 speed BW ST-10/Cliff Q-Jet/XE268/3.08
99 Trans Am/383 LS1/TSP headers and catback/custom grind cam/Vigilante 2500/Strano springs and Konis
08 Corvette - Base
(SOLD) 75 Corvette/L48 350 (LSx -4L60E one day)
Old 04-15-2004, 12:37 PM
mechanickeith's Avatar
Paul, Give me a call this evening, I will see what I have available in helicoils & keenserts
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 04-15-2004, 01:44 PM
Will do, Keith. I was just shopping helicoils. For the size I need, $150 bones not including the drill bit. Ouch!!!
