Old 04-08-2004, 04:15 PM
71judgedrvr 71judgedrvr is offline
WELL, SEEMS I DIDNT DO MY RESEARCH WELL AND THE NEW WHEELS AND TIRES I PURCHASED ARE TO BIG... I BOUGT SOME AMERICAN RACING TORQUE THRUST D'S IN 15x8.5" FOR THE FRONT AND REAR WITH SOME BFG 275/60R15 AND 245/60R15 TIRES... THE REAR END IS ABOUT AS HIGH AS IT WILL GO WITH THE AIR SHOCKS ADJUSTED... (LOOKS HORRIBLE) AND THE FRONT RIGHT RUBS IN THE FENDERWELL REALLY BAD... HOW CAN MAKE THIS COMBO FIT? SHOULD I JUST SELL THE WHEELS AND GO BACK TO 15x7? SOMEONE PLEASE HELP!! CAN I MAKE THESE WORK? MAYBE B BODY SPINDLES UP FRONT WILL ADD SOME ROOM... ALL I NEED IS ABOUT 3/4"... AND ABOUT AN INCH IN THE BACK... THANKS!
Old 04-08-2004, 08:05 PM
You may be pooched. I bought some Centerline's in 15 x 8; they rubbed fiercely- had to go to 15 x 7 and they run flawlessly,
Old 04-10-2004, 04:45 AM
smi481 smi481 is offline
check this out (once get past the miata thing its still cool) runs in java.
http://www.miata.net/garage/tirecalc.html
I think I am running 235/60r15's on rallyII's on mine. So your 254/60r15 are not much wider (I assume they are on the frount) and the 275' are on the rear. (they maybe to big) the question is where do they rub? what back spacing did you order? I saw somewhere a guy just running 16x10 rims on the rear I can no longer find it but I have it saved at home, body all stock no rubbing. You may be able to get longer wheel studs and a spacer plate but its hard to say with out the backspacing or knowing where they rub at.
Old 04-10-2004, 06:45 AM
Txbobcat Txbobcat is offline
I tried on a set of 2756015 on the back with 25560 on the front. The 275 would rub on a hard curve so I went to 25560 and 24560 and all is well. This is on rally wheels
Old 05-10-2004, 03:48 PM
dwainm dwainm is offline
Some friends and I have run 10" rims with 295 50/15s on the backwith no problem. The fronts may be too wide. What kind of offset do they have?
It's Injun Joe, the Superchief, woo woo!
Old 05-10-2004, 05:23 PM
ra4jumb ra4jumb is offline
I have run 275 50 r15 on the back with torq thrust d's with air shocks on a 69 had to go with 15x7 with 235 60 r15's on the front and they worked fine. I don't remember the ofset, but they are close but dont rub with freash springs. I would check for you but I am in Iraq and doubt they will let me go home to check them.
Old 05-11-2004, 12:35 PM
greg greg is offline
I had 15x8 cragers on the back with 275/60/15 without a problem. Now I just put on 17x8 all around with 255/45 out back and 235/45 in front and both work fine. Your problem may be the offset. I have mine at 4.5".
1971 GTO Convertible 4 Spd
