Old 04-16-2004, 09:49 PM
403olds 403olds is offline
I have a 79 t/a with an olds 403. I have been having trouble getting a spark and starting the motor over the past few months.... the motor will crank fine but Half of the time I try to start it I get no spark.... I replaced the distributer, cap and rotor, module, plugs, coil, and wires.. its all new but I still get this problem half of the time. If i get the car started, it sounds like I have a dead cylinder until it warms up, then its fine. It also runs like that as soon as I get off the highway and will stall out if I don't pop it into neutral at a stoplight. After I realized that I couldn't figure it out myself I took it to some garages, every one says that its a different problem, says they fixed it, but after a week or so im back where I started. any suggestions?? Thanks
Old 04-17-2004, 01:14 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
I know you said you replaced the distibutor, but I had a similar problem with erratic starting problems and it was my pick up coil. As far as the dead cylinder until it warms up, I dunno. Do you have a big cloud of smoke coming out like you are burning off a flooding situation? Maybe your carb is leaking out the bottom plugs while it sits? Just taking some guesses. By the way welcome to the board!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 04-17-2004, 08:53 AM
george kujanski's Avatar
Jay, next time you have a problem, jump the HEI batt wire to the battery directly. that will bypass any internal wiring issues to the ignition switch. You should definitely get spark, and if it still doesn't fire, your problem is elsewhere.
George
