Prev Previous Post   Next Post Next
Old 06-02-2003, 05:08 PM
GTO's Avatar
GTO GTO is offline
Just fired up the new 469 pump gas motor in my Pro Street, and to my dismay almost lost it because of a bad filter! It started good and I adjusted the idle at 2000 RPM and played with the throttle for cam break-in. I checked oil pressure and it was at 30 idling at 2000- 2200 and the temp. was good. I went back up front and played with the throttle while checking for any leaks. When I checked again the press. was down to 20psi. This time I climbed in and worked the throtle while watching the gage. As I increased RPM the oil press. decreased so I shut her down. Turns out to be a bad FRAM PF25 filter. I had just picked up some HP2 filters for the oil change so I changed the filter and the pressure was back. Thank God! 35psi at 2000 and 60 at around 4000! They're gonna get this one back! ... Eric
Runner Up Q16 Norwalk 2013!
