Old 08-21-2004, 08:38 PM
cls cls is offline
They are now taking orders...got a letter 2 days ago....intake and heads roughly 7500.00
1970 Trans Am
Vortech X Trim
397ci Ram Air V
cls cls is offline
1970 Trans Am
Vortech X Trim
397ci Ram Air V
Old 08-21-2004, 09:24 PM
GTOGEORGE's Avatar
Ok, will someone please explain to me why the DCI head is almost $6,000 which is 3 times more then KRE's head. Both are made out of the same Aluminumm both have a lot of R & D behind them, both are Pontiac heads. We aren't talking $1,000 more but.......$4,000 more?
Old 08-22-2004, 09:46 PM
Tom McQueen Tom McQueen is offline
Did I miss something? Have we even seen an engine built and dyno'd with these heads? If there was one, what were the results? Dont misunderstand, this isnt negativity, just a request for data. Hard information has definitely been lacking on these parts. Absolutely no info on the website. Thats a whole lotta green to shell out blind.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
Old 08-22-2004, 10:12 PM
BVR421's Avatar
BVR421 BVR421 is offline
its must be marketing, make them a mystery, make them nearly unobtainable and keep the price skyhigh LOL
they go on the dyno in a couple months for all the world to see. DCI heads tuned by Dale Eicke of prostock fame.
410ci the PHR smallblock shootout. I hope they make a good showing among the 7 Pontiac entries.
they will have to show significant power over the independent entries with home ported KREs and Eheads.
several thousand dollars of significant power
Old 08-23-2004, 06:06 AM
PONTIAC DUDE's Avatar
I remember when the S.C. heads became available. Larry didn't have cars running those heads before they hit the market. He stated #'s and people bought them. Even and especially knowing the past issues his previous heads had. And the issues they even come with and knowing that they will need to be fixed or repaired after they were purchased.
So what's the difference. Between then and now?
Except that the DCI heads are being bad mouthed without anyone even using them. I just don't understand?
Pricy....Yes and Big time.
Especailly since a 460 Ford head produced by Trick Flow is $2100.00 complete and flows out of the box over 400 cfm. And any BBC head can be purchased for the same price flowing over 375 out of the box. <span class="ev_code_RED">Complete</span>
Old 08-23-2004, 09:08 AM
Brian Baker's Avatar
George - KRE doesn't have a 400-cfm head, do they? I'm sure their billets are somewhere in that neighborhood, but I don't think you want to know the price on their custom billets.
Ken - the difference between then and now is, NOW there is already a proven head available flowing the same figures that DCI claims. When Larry introduced the S.C. there wasn't another out to compare it to...so racers bought them, in a sense "sight unseen". Time has passed since and the S.C. head has proven its worth. DCI is going to have an uphill battle selling this head UNLESS they can first prove its worth, because EVERY potential buyer is going to compare it to the S.C. head. This is why it would behoove DCI to donate a set of these heads for R&D to a racer in exchange for promotional interests.
Old 08-23-2004, 10:59 AM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by BVR421:
several thousand dollars of significant power <HR></BLOCKQUOTE>
We have been working with several of the Engine Master's Challenge teams and can tell you that no Engine Master's Challenge engine will have the DCI head on it, if for no other reason it was not commercially availble by the cutoff date for legal parts.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 08-23-2004, 12:13 PM
BVR421's Avatar
Wade, I wondered about that, because I didnt think there was any current availability.
On the other hand, in the new PHR mag, the blurb for Eicke, Wood & Johnson, makes mention of Dons new 400 heads and quotes Johnson? " ---the new DCI Motorsports cylinder heads will be maximized for performance in the target rpm band----"
While I could find no definitive sentence clearly stating the new heads will be on the dyno, it very much sounds that way.
Old 08-23-2004, 01:15 PM
...in the new PHR mag, the blurb for Eicke, Wood & Johnson, makes mention of Dons new 400 heads and quotes Johnson? " ---the new DCI Motorsports cylinder heads will be maximized for performance in the target rpm band----"
<HR></BLOCKQUOTE>
This guy could be a politician...or a fantastic salesman.
If the head performs on par with the S.C. head, they're heroes.
If it fails, they can say their intention was never to go head to head with the S.C. head.
Only problem is, with a projected price higher than the S.C. head, they'll be shooting themselves in the foot if it doesn't produce "par" numbers.
"Target RPM band".....indeed.
Old 08-23-2004, 02:03 PM
D. Miles's Avatar
D. Miles D. Miles is offline
Is that $7,500.00 for complete heads and an intake because that wouldn't be a bad price! But if that is for bare heads, then whooaa!!! If I think correctly aren't the WENZLER S.C.'s $1,300.00 for bare castings? D. Miles
Going TurboCharged!
Old 08-23-2004, 03:17 PM
I believe the ONLY way the heads are available is in complete form.
Old 08-23-2004, 08:06 PM
J.C.you's Avatar
J.C.you J.C.you is offline
i see they have a website started, but no info?Dragula, car to share their letter and their claims, if any?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 08-24-2004, 09:42 AM
cls cls is offline
JC.
I think the letter said the first production run was limited to 25 pairs of heads...other than that it wasall the info we have heard before about them flowing 400 cfm right out of the box. They are also offering the IA2 block for 2995.00
I threw the letter away b/c it took them to long to become available so I had found another set of heads with comparable numbers.
1970 Trans Am
Vortech X Trim
397ci Ram Air V
Old 08-24-2004, 02:38 PM
GTOGEORGE's Avatar
Let me clear something up when I asked why the DCI head was $4,000 more then KRE'S head I was not knocking the DCI head. In fact if I already hadn't bought a set of Superchiefs I might have been one of the first to order a set from DCI (can't afford both). But I still don't understand why they are $4,000 more.........$1,500-2,000 more maybe. They are both aluminum Pontiac heads, they both have had an awful lot of trying & testing done on them. I give.
Old 08-24-2004, 02:55 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by GTOGEORGE:
Let me clear something up when I asked why the DCI head was $4,000 more then KRE'S head I was not knocking the DCI head. In fact if I already hadn't bought a set of Superchiefs I might have been one of the first to order a set from DCI (can't afford both). But I still don't understand why they are $4,000 more.........$1,500-2,000 more maybe. They are both aluminum Pontiac heads, they both have had an awful lot of trying & testing done on them. I give. <HR></BLOCKQUOTE>
George, if you're comparing the DCI head (which sounds like it will be a race head for the same market as the Wenzler S.C.) to that of KRE's new aluminum d-port head.....apples and oranges.
KRE, to my knowledge, doesn't offer an "off the shelf" 400-cfm head, in any form. Now if you'd like a set of their custom billets, like Mellot has on his car, I'm sure they're more than the S.C. or the DCI head.
Old 08-24-2004, 06:55 PM
GTOGEORGE's Avatar
Brian,
Your missing my point. I understand that the DCI is a race head and KRE's head is a street & strip head, my point is both heads are made the same way and are made out of Aluminum. OK let me try this ......2 pairs of tennis shoes , one pair is a running shoe and the other a cross training shoe. Both are made out of the same material and each is special for it's own application...they should be priced about the same (or some where in the same ball park), get the picture.
Old 08-24-2004, 07:06 PM
GTOGEORGE's Avatar
Brian,
Lets try this.......2 Roller camshafts, one is for the street and the other is for the strip. Now the only difference is their lift and duration. Both are made of the same material and both made for a Pontiac, so they should be priced pretty close together(or in the same zip code). How is that?
Old 08-24-2004, 07:14 PM
George,
Take 2 cars...a Cadillac and a Saturn. Both are made from steel, glass, plastic, rubber, etc. Both are built on assembly lines. Both will get you from point A to point B.
Why is the Cadillac 20 to 30 thousand dollars more than the Saturn?
Do you get the picture?
Both the KRE and the Edelbrock heads will see (and for the E-heads, have seen) a larger market than the S.C. or DCI heads will see (or have seen). The higher the number of units sold, the lower the price.
Also, like the Cadillac differs from the Saturn, so too do the design of the DCI and S.C. heads differ from KRE or E-heads.
There is your price difference.
Old 08-24-2004, 07:35 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Anyone know what the flow numgers are on a max ported Victor? The new DCI heads are reported to flow OVER 400cfm . Makes me wonder who will step up and make an intake that will work with them well. I think that DCI plans to go all-out and win the PHR Engine Masters contest. They have to make a VERY GOOD showing or it will be a marketing blunder. When do they start the dynos and does anyone here have an inside spy link?? Thanks-JimT
