Old 06-21-2004, 08:53 PM
mrchuckles mrchuckles is offline
I get a small amount of water in my trunk after I wask the car. It is a 64 GTO with a somewhat sloppy fitment on the trunk. I don't have any rust around the rear window, but it might be coming in there as well.
What is the best way to pinpoint the source of the leak? I don't want to mess with the rear glass unless I'm sure the leak is there. Thanks.
Chuck
Chuck
Old 06-21-2004, 09:16 PM
78 GHOST 78 GHOST is offline
Get a flashlight, get a helper (with a trunk key in hand.. who likes you), climb in the trunk, shut lid, have helper run water all around rear window, find leak, curse, open trunk, fix leak, drink beer.
____________________________________
"I work in high speed aluminum tubing."
Old 06-22-2004, 06:27 AM
Rob79TA Rob79TA is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by MrChuckles:
Chuck <HR></BLOCKQUOTE>
have you tried to ajust the fitment of the trunk? I would start there.
Old 06-22-2004, 09:43 AM
gtoformula's Avatar
gtoformula gtoformula is offline
Hi - this is Rick from the GTOANT. I had this problem with my Catalina. I crawled in the trunk (it's huge) with a flashlight while my daughter ran the hose. It took quite a while before I found a water trace. If you get water after washing the car it should be easier than was mine.
The simplest area would be around the trunk opening perimeter weatherstrip. This can also be checked like door opening weather strips. Take a piece of paper (about 4" x 1") and close the trunk so that the paper is pinched by the trunklid/weatherstrip pressure and still sticks out far enough to grap an edge. Pull on the paper. Move it around the perimeter of the seal and find where it pulls out without much resistance. That is the area that will need work.
My trunk leak was due to corrosion of the back glass channel. I had to remove the backglass and rebuilt the channel. It still leaked a bit. Turns out that a pin-hole still existed and was leaking between the filler panel (below the backglass) and the inner trunk structural panel. When I found where it was coming in I had to use use a hole saw on the end of a drill to open an area large enough to access and chaulk. Not fun.
Tip: if you put the trunk key in the lock tumbler you can use pliers or a crescent wrench to turn the latch rod while inside the trunk. That way you always have a back up way to exit the trunk (like if my daughter was pissed at me and wanted to get even).
Old 06-22-2004, 01:29 PM
dwainm dwainm is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Matt D. 78 GHOST:
Get a flashlight, get a helper (with a trunk key in hand.. who likes you), climb in the trunk, shut lid, have helper run water all around rear window, find leak, curse, open trunk, fix leak, drink beer. <HR></BLOCKQUOTE>Make sure it's someone you trust. That's the important part. Oh, one more thing, make sure you have all ignition keys before you get in the trunk.
It's Injun Joe, the Superchief, woo woo!
Old 06-22-2004, 01:47 PM
Mase Mase is offline
I used red food coloring and water to diagnose that in a Chevelle I had.
Mase
Old 07-02-2004, 09:05 AM
nosliw nosliw is offline
i just layed a big chunk of cardboard in there and showered water over the closed trunk with my hose.
