i've got a 68 grand prix and i was wondering if i could swap out the front drums for disc brakes from another GM car. i've been looking for aftermarket kits to do it and no one makes jack for a 68 or older GP. can someone please guide me in the right direction? your knowledge and help would be much apprreciated.
Only late 68-70 full size Pontiacs will have the parts to make the best disk conversion. The 67-early 68 brakes are expensive and lack parts to make it worth while. Good luck Pat
what exact parts would i need and what would be the best or most common 68-70 pontiac to pull them from? is it possible to get the parts from a later model pontiac and if so, which way (68-70 or later model) would be easier?
thanx chano |
check out this site, http://www.scarebird.com/
Is working on a disk set up that will use modern parts. Other wise you will need to look at 68-70 full size cars. Bonneville, Executive, Catalina, Ventura, and GPs. Hope this helps. |
You need the booster master cyl front brake lines spindles calipers rubber hoses and will have to go to 15 inch disc wheels.
A week after I put mine on I was 4th in a 3 car accident and a 4 wheel disc Honda had to change lanes to keep from hitting me in the rear. |
Sorry to hear about the accident.
