just bought some Judge stripes from PY, but they don't have any location instructions. Where would I find the dimensions for the stripe locations. Thanks
The 1969 Assembly Manual has a whole page of DETAILED installation drawings. Year One has the manual. Cost is $52 + shipping.
Does anyone have this info online?
I want to put the strip on a 68, so I really don't want to purchase a 69 manual. This is not going to be a clone, I just like the stripe and think it will look great on my white 68.
On the '69s that I have had the drivers door stripe goes just below the door mirror base & above the door handle. It should run parallel with the upper body line. The fender & 1/4 stripes should follow the line set by the door stripe.
HTH, Steve |
pggto, here is a scan of the '69 "The Judge" decor installation drawing. At 72 dpi, the hand printing is pretty hard to read, let me clarify some of the key measurements:
Starting at the front; View A, point of stripe is 3.60" back from the fender front edge and 0.80" down from the fender peak. At section B-B (30" from rear of fender) the stripe is 0.54" below fender peak. At mirror gasket, 0.10" min clearance. At section F-F (24" from front of door) 1.94" from feature line. This measurement should remain constant to a point 15" to the rear of the door opening. At door handle, 0.10" minimum clearance.
Thanks guys, this should be what I need to install the stripes.
Thanks for the help guy's, it turned out pretty good.
PG- Did you buy this 68 in West Bend? There was one like it for sale a few months ago.
Looks Great !
Can someone please tell me the dimensions for the placement of the Judge fender decal. I can't read the #'s unfortunately. Thanks!
At the upper fender peak the measurement is 3.40". Measure down 5.95" to the top of the applique, At the bottom of the applique the measurement is 5.60" back from the fender front.
Hey what page is that diagram on i can't find it anywhere you got that out of the pontiac gto restoration guide 1964-1972 right? i have the 2nd edition from mbi.. thanks!!
Looks like it came out of:
"If your lawyer's asleepin' better give him a nudge, everybody look alive, now here come th' Judge." - Sammy Davis, Jr. '69 Expresso Brown/Gold RAIII Judge HT '86 Carmine & Black/Red 1.8L NA Sunbird GT Convert. '03 Montana EXT Pontiac 1926-2010?
