Old 07-02-2004, 03:11 PM
A1Judge's Avatar
A1Judge A1Judge is offline
Well I pick up my block and crank tomorrow.
While waiting for the machine shop to do their thing I settled on the Summit 2802 cam and lifter set, they arrived today. The lifters are HT-951 and seem VERY EASY to push down on. I can depress the plunger about 1/4 inch with my finger. My old Crane lifters that I have are very hard to push down, can't do it with a finger at all.
So my question is, are these HT-951 lifters any good? I know they are made by Melling, but why are they so weak?
Should I take the guts out of the Cranes and put them in the HT-951 bodies? Or just install them as they are?
My 70 Judge Restoration documented at: http://thejudge.dyndns-home.com:8080/
A1Judge's Avatar
Old 07-02-2004, 06:43 PM
Doug Christie's Avatar
Doug Christie Doug Christie is offline
Just lube them and install them. They're weak because there's no oil in them. Prime the oil pump be for starting and go beat up on some rice.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something."
Old 07-04-2004, 04:05 AM
buwalda buwalda is offline
The spring you can feel is there to push the inner piston up against the circlip, so it has some 'feel' when adjusting the lifters. The lifter will actually work without that spring.
Old 07-04-2004, 04:51 AM
A1Judge's Avatar
Thanks, I will leabe them alone and use as is.
The motor assembled nicely, clearances are all within spec.
They only had to turn the mains on the crank an additional .01, so it is now at .02 under.
It is assembled to the oil pan. Took me all day, (11 hours), as I spent a LOT of time cleaning everything for a second time before I installed the part. I should have it all back in the car and ready to break in by next weekend.
Old 07-04-2004, 05:33 AM
trumpeter trumpeter is offline
I just assembled my 455 with the summit 2802 cam and lifter set. I sumerged my lifters in a bucket of oil and worked the plunger with an old pushrod to help get oil in them.
Trumpeter
Old 07-04-2004, 02:35 PM
A1Judge's Avatar
Did the bucket of oil trick today and got lots of air out of the lifters. Seemed to work very well.
Coated the base with Moly lube and installed. (Of course the cam is fully coated with Moly lube too).
Stuffed the engine and tranny into the car together as a unit today. Too tired to continue - but hopefully I will get to fire it up and break it in on Saturday.
