Old 01-23-2004, 12:49 PM
dennisk dennisk is offline
Pulling the interior out of this car and found this under the seat. ANy ideas what it is? Thanks.
Old 01-25-2004, 11:31 AM
meanolegoat meanolegoat is offline
item on left looks to be a baro sensor, middle is
a common relay, used for fans, fuel pumps, vats system, etc..., far right looks to be the esc
controller.....really need a manual. stange location for those items. I had an 86 t/a never noticed them. Is yours a tune port??? Mine was a
carbureted 5spd. If memory serves those items were under hood on mine, and i had no vats system....
Mean
Old 01-25-2004, 06:07 PM
I have several answers to my question. It goes on the firewall near the brake booster and its a MAF sensor, and a fuel relay and something else. Not using it so it will go on EBAY.
Old 02-19-2004, 04:34 PM
bjsgoat bjsgoat is offline
That is definately NOT a MAF sensor!
Old 03-15-2004, 04:32 AM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
They didn't have Tune Ports until '87.
_____________________________
www.classicpontiacrescue.com
Old 03-18-2004, 02:35 PM
thirdgen455's Avatar
thirdgen455 thirdgen455 is offline
86 for TA's and camaros, and a few 85 Z28's came with TPI's
Old 03-19-2004, 06:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by bonneville Joe:
They didn't have Tune Ports until '87. <HR></BLOCKQUOTE>
85 in limited production in the t/a for the tuned port.
crossfire was used in 82-3.
from left to right.
map or baro sensor. looks to be a relay for fuel pump. esc module is on the right.
mike
former." --Albert Einstein
- Winston Churchill
Old 03-29-2004, 06:06 PM
Judas Judas is offline
Agree with the above. My Dad had a 85 with a TPI and every option in the book. It was sharp looking (car and engine) For a 305, it wasnt too bad running either...until my brother drove it into a jersey wall. He was ok, car was not. A real shame cause I havent seen an 85 like that since. I always wanted to drop a 383 in that bad boy...
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward."
