Old 08-08-2003, 02:58 PM
Coach's Avatar
Coach Coach is offline
I took a little ride out to the Cleveland area and picked up some more goodies for my '67 GP convertible project. As I was chewing the fat with the gent I bought the parts from he mentioned he had a set of long fin 8-lugs for the later model full size Pontiacs. After looking over the set and checking to see that there was still some linings left I bought them for a very fair price. Now I need to figure a few things out.
1) Where is the best place to get a set of center caps and trim rings. Nice used units would be good. Are the rings specific to the 8 lug wheels or are they the same as the 14" Rally rings.
2) How are these supposed to be finished? What finishes/colors are used on the hubs, fins, and rims?
Thanks in advance,
-harry
1967 Grand Prix Convertible Project
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
Coach's Avatar
Thanks in advance,
-harry
Old 03-18-2004, 09:17 AM
gtoric's Avatar
gtoric gtoric is offline
Coach,
Don't know if you still need help here, but I'll check in with some opinions.
1) The 8-lig trim rings were specific to that wheel. Repop trim rings were available for awhile. Don't know the application or the current availability. Check PY to see what they might still carry. Center caps are strictly a used-market item. Ebay, Smoke Signals, Hemmings, or swap meets.
2) I restored a '67 GP convert several years ago and during the process restored a set of 8-lugs. I bead blasted the hubs, painted the entire center section face a high temp black. Then, with a hand drill, I polished the flats of the fins with a 6" diameter 120 grit stick-it paper on a sanding pad. The rims were refinished in black.
Old 03-22-2004, 08:40 AM
gpmodelj70 gpmodelj70 is offline
65-68 8-lug center caps are now reproduced along with the trim rings and lug nuts
Marriage is defined by GOD, not by popular culture!
Old 03-22-2004, 11:56 AM
Coach's Avatar
I've seen the trim rings, do you know who is distributing the center caps? I recently picked up a set that I was going to straighten and polish, but it might be more cost effective to replace them.
Thanks,
-harry
