I have a 1976 400 and need a oil pump drive rod.I bought a melling from a local auto store.It has 2 notches which doesnt allow it to drop all the way down.Can these filled off or does anyone know about this. Thanks
[This message was edited by Brett Wray on December 13, 2003 at 09:49 AM.] |
Filing or grinding off the two 'notches' is commonly done when installing it from the top since that's the only way it will go in from up there.
It is usually installed from the bottom but some builders forget to put it in before the oil pump and oil pan go on, hence the fairly common removal of the offending 'notches'. Welcome to the PY forums. ------------------------------ Some say the glass is half full, others say the glass is half empty...I say 'Are you gonna drink that?' www.outlawpontiacs.com/members/B-Man2.php www.outlawpontiacs.com/members/B-Man.php
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
I've only forgotten to put the oil pump drive in, before the oil pump, once. Like b-man said just grind off the tangs. Be sure to clean it thoroughly before you install it.
Bill
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. [email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
