My machine shop has a pontiac performance freind that tells him, if he puts the pistons in backwards(to where the notch points to the back of the engine) tye 60 400 engine will make more power. Anyone heard of this? Thanks
Somebody's smokin' dope!
You know it's going to be a good day when you wake up breathing! |
I've heard of guys doin this in small block chebs to get rid of side loading on the piston and free up a few ponies.It moves the pin in closer to the cam and for all practical puposes does its job but decreases the longevity of the engine due to increased loading of the crank at the main caps.And we all know about loading Ponts in the mains causes cracked webs
http://community.webshots.com/user/stripleduce |
I don't think it works.
The real reasons why the pin is offset are: A.) Quieter running engine (less piston slap noise on cold start up). B.) Easier on the rod bearings (a "glancing" blow on the bearing the the spark plug goes off is easier on the bearing than a "straight on" blow). Most racing pistons have the pin location centered. I can't imagine why anyone would want to run an OEM piston backwards in any application nowadays.
It is an old hot rodders' trick. It works...just look at the stock Hemi piston offsets. By moving the offset you geometrically create more dwell at TDC making the engine work like it has a long rod.
It does increase side loading on the cylinder wall at BDC and not recommended for a street car. Dave "Big Injun" Anderson www.pontiacdragdays.com www.geetotiger.com
Dave "Big Injun" Anderson [email protected] www.4mypontiac.com For GTO Celebration items click the tile coaster.
The negative long term effects outweigh the small amount of added performance you may gain. There are many other upgrades you can do that would be much better for the engine than this.
This is an old Joe Sherman trick, and it does work at the expense of additional engine noise and perhaps decreased engine life.
I think some of the "stockers" do it. Shave off the arrow and restamp the piston top.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Skip Fix:
I think some of the "stockers" do it. Shave off the arrow and restamp the piston top.<HR></BLOCKQUOTE> I think NHRA rules allow for the stocker to have the pin relocated to the center of the piston. They also allow for an overbore (but not much). They're not using OEM cast pistons in Stock or Super Stock.
As Big Dave said.
It works. Not for daily use. As it was a racing trick that "Everyone" knew. Build it fast, build it right, build a Pontiac. http://PontiacDude.cc |
Brian, some of the guys still use TRWs and they are on the NHRA approved replacement list. Venolia, and some others have some. I know John Schloe was still using factory RAIVs in his motor when I talked to him a few years ago. I think the pin offset has to stay the same in stock, most guys use a Dykes top ring though.
Super Stock pistons are wide open though.
