Old 05-26-2004, 02:54 PM
ejw71 ejw71 is offline
Will 73 455 heads bolt up to a 67 400? If so, can the 67 intake be used or must I use the 73 intake? Thanks, Ed
64 Catalina/Ventura/389/auto, 86 Fiero GT/173/4sp
Old 05-26-2004, 03:15 PM
Txbobcat Txbobcat is offline
I believe everything from 65 and up will interchange.
I used to have a 67 Cat convert many years ago loved that car.
Old 05-26-2004, 09:19 PM
you'll need to check the valve sizes on the 455 heads. the block may have to be relieved so they'll clear the cyl wall.
they will bolt up tho, just may not work right.
mike
former." --Albert Einstein
- Winston Churchill
Old 05-29-2004, 03:26 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
Also, watch the valve clearance on the pistons themselves. Might need a dished or relieved piston.
_____________________________
www.classicpontiacrescue.com
