Old 11-03-2004, 04:16 PM
old gto old gto is offline
The flywheel on my 455 seems to be missing some teeth. It`s in a `69 Grand Prix. Can I replace it by just dropping the trans and taking off the torque converter? The only times I`ve had to deal with a flywheel was with both engine & trans out of the car.
66 GTO, 69 Grand Prix
The only thing I`m sure of...is that I`m not sure of anything!
Old 11-03-2004, 04:27 PM
a73formula a73formula is offline
You can do just what you said. I'm not sure but you may be able to get to it by just taking out the converter and then dropping the flexplate out, but I'm not sure on that.
Old 11-03-2004, 04:29 PM
68MeanVerdoroGreen's Avatar
68MeanVerdoroGreen 68MeanVerdoroGreen is offline
Old GTO,
That should work. Have a torque wrench on hand to have to torque the flywheel bolts to spec. I clamp a set of vice grips to the flywheel to disable it from turning when breaking loose and tightning these bolts.
Larry Metzger
Columbus, NJ
1968 GTO Verdoro Green Hardtop
1969 GTO Palladium Silver Hardtop
1969 Judge Carousel Red Hardtop X 2
Someday We'll Look Back On This And It Will All Seem Funny.
From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973
