Old 10-10-2004, 12:35 PM
taruls1 taruls1 is offline
i need to know if there is a fuel pump reset on my 1998 trans am ?
i ran out of gas and can not get it to restart.
HELP!!!!
HELP!!!!
Old 10-10-2004, 12:40 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Likely just that the fuel rail has lost PSI and volume. Try cycling the key off to on about 5 times, leaving it on for about 3-4 seconds each time, but NOT cranking the engine. Then try staring it. Most fuel pumps prime with ignition on for about 2 seconds...if you try to prime it, the fuel volume and pressure will replenish itself all the way up to the rail....and car should start.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
