Old 11-25-2004, 09:30 AM
trans am ed trans am ed is offline
what has to be done to put a hemi 4-speed in a pontiac. thanks ed
Old 11-25-2004, 09:34 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The old early Pro Stockers did that. I know the have a different spline input and output shaft(early Doug Nash 5 speeds sued the same splines). I don't remember if they had to redrill bellhousing or not.
Skip Fix
Old 11-25-2004, 09:38 AM
wheelspin's Avatar
Ed,
Why ruin a perfectly good Pontiac with a Hemi .
Just kidding, out here in SoCal most folks buy a really ugly sixties Polara post, add the Hemi, make up a racing pedigree for the "clone", and sell it for a truckload of $$$.
If you can't figure out how to make the swap, I'll take that old Mopar boat anchor off your hands .
Les
Les Iden
Old 11-25-2004, 11:38 AM
Tom McQueen Tom McQueen is offline
I currently have a Chrysler A833 (Hemi) 4 speed in my street 70 GTO. Liberty modifys the input shaft to be the correct length, and adds the correct pilot bearing onto the end. You still need the correct clutch disc (11" dia, 18 spline). Liberty also puts one of their bearing retainers on so it will register properly in a GM bellhousing. The bellhousing needs to be modified to take the Hemi trans bolt pattern and you need an adapter to set the trans mount to the correct height and adapt to a GM mount. The crossmember will need to be moved back. You will need a Super Shifter shifter and whatever stick puts the shifter where you want it. All in all not very difficult.
My setup has all of 50 miles on it, and this weekend Im putting a TKO-600 5 speed in the car, so the complete hemi trans conversion from clutch disc bellhousing, tranny, trans mount and Mark Williams 1350 yoke will be for sale. The gearset in mine is 2.65/1.93/1.39/1.00. E-mail me if youre interested.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
Old 11-25-2004, 05:35 PM
Schoust's Avatar
Schoust Schoust is offline
Don'think my 21 is going to hold up when it hooks.How much???
