Old 04-21-2004, 09:39 AM
formula_73 formula_73 is offline
I have a 73 formula and am looking for a new exhaust system. I'm going to install hooker super comps but I don't know wether to get aluminized, stainless, etc. I also want a good fitting sytem as well. Which is best and why? Any help? I want it to be a 2 1/2 system mandrel bent. I was thinking of getting a system from PYPES with the X crossover but I think they only offer their systems aluminized. Any advice?
Old 05-07-2004, 07:46 PM
Can't anyone help? Who makes a good stainless system? Why is it better than aluminized? Is it?
Old 05-08-2004, 08:16 PM
Cant help with who makes stainless. Aluminized is just mild steel tubing with a very light alum. coating. It will rust quickly any place the coating is disturbed. On the other hand stainless will last vertually forever.
Old 05-10-2004, 12:16 AM
NW S/D's Avatar
NW S/D NW S/D is offline
Without going custom for big $$$, I am not aware of who makes an over-the-counter system in stainless. I bought the Pypes 3" X system and am very satisfied with it. It, however, is not for eveyone. Ground clearance may be an issue and should be considered seriously on a daily driver. My car is not a daily driver. The Pypes system has a lifetime warranty. Ccass, correct me if I am wrong.
1973 Super Duty Trans Am 455SD, Auto,White/White, Best Et: 11.39 @118 on Drag Radials 3875#
Old 05-10-2004, 06:33 AM
Donovan Donovan is offline
Here you go... Mandrel bent! $800 for stainless in any true dual configuration you want. 2.5" or 3". Headers also. You can also get a factory style single setup if you wanted.
None of their systems come with a crossover of either type included,
http://www.stainlessworks.net/Camaro%201967-1981.htm
You can buy a stainless crossover seperate and add it in for about $200-
http://www.stainlessworks.net/X%20Cr...20Adapters.htm
______________________________
1968 Firebird Coupe - 3665 lbs.
350 HO
Long Branch Manifolds
TH350
3.23 open BP axle
PS, PDB and Deluxe interior
GPE Starter ... Small body HEI ... 2.5" Pypes w/X-pipe ... Ruggles Qjet
14.1 @ 99.1
Old 05-10-2004, 10:40 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Yes, we offer lifetime warranty on the pipes and the mufflers. Expect our system to look good for 7-10 years and last 10-15 years on a well maintained classic. (ie; garaged and not daily driven) We recommend you use a high temp spray paint on exposed welded areas of the system.
Stainless advantages; Will never rust.
Stainless disadvantages; Tinny sound, difficult to keep clean, generates underbody heat and cost.
The systems on the link above are high quality. However, they are not designed for Pontiacs. The crossover will require modifications for best fit. The tailpipes will require modification to use a factory type tip.
Old 05-17-2004, 07:36 AM
I think I'll go with a pypes system. I have Super Comps with a 3 1/2 colector. Will they fit good with the pypes system?
Old 05-17-2004, 08:04 AM
NW S/D's Avatar
I belive they will, for a neat way to do your hookups try useing 3" to 31/2" reducers with stainless band clamps, this will allow for maximum ground clearence. JF
Old 06-18-2004, 02:45 AM
Now i have a problem. I just found out that the headers I got won't fit with my type of heads. They were made for HO/SD/RaII & IV type heads. I have 4X heads. I noticed when double checking to buy my system I was about to get the #RFE93BKQ or #RFE93CK2 set but didn't know what the difference was. I'm assuming it was just the muffler type. But now I think I'll be needing either new headers or new heads.
Old 06-18-2004, 07:27 AM
dm_fan's Avatar
dm_fan dm_fan is offline
Administrator
Formula:
Did you get Factory Castiron Headers (we refer to them as Manifolds) or did you get Longtube Headers (ie. Doug's or Hooker)? Where did you get them and will you be able to exchange them?
RFE93BKQ is a 2-1/2" system with Goerlich Bigmax 14" Mufflers. RFE93CK2 is a 3" System with Pypes 14" Mufflers. Both systems will fit Longtube headers or Manifolds (if you add downpipes).
"No you fool, we're following orders. We were told to comb the desert so we're combing it."
Old 06-18-2004, 08:32 AM
Ron's Avatar
Ron Ron is offline
The good bad news you have the wrong headders. The good news is now you can purchase Doug's Headers and a complete system from Pypes at a great price. With this system you will be a very happy person.
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 06-18-2004, 01:59 PM
disc0monkey's Avatar
disc0monkey disc0monkey is offline
yes dougs headers, just installed them, email me if u want pictures
Old 06-18-2004, 09:37 PM
I was thinking of doing the same thing (getting Dough's headers with a pypes system) but is the Doughg's header #THY-341 the right type. If so why does it only have three pipes? How much can I get a set for? Bad news is I don't think I can exchange them because I already had them coated by jet hot.
Old 06-18-2004, 11:05 PM
Ron's Avatar
Ron Ron is offline
I think the part number you have is for a set of Doug Thorley Headers. Not the same company as Doug's Headers. Doug Thorley Headers is a company that was owned by Dougs ex wife and sold to another company in the last few years when she died. Old technology, old designs, just plain old krap. Doug's Headers are new designs, fit great and perform well. They are four tube designs.
Old 06-20-2004, 10:00 PM
Oh, Sh** I had no idea they were different. All this time I heard you guys talk about them and how great they were but I didn't like the fact that they were a three pipe design. Can you give me the name of a website that sell the ones I'm looking for? Thanks for keeping me from making, yet again, another mistake.
Old 06-21-2004, 10:15 AM
Ron's Avatar
Ron Ron is offline
Two great places to purchase Doug's Headers. You can purchase them from our host, Performance Years or you can purchase Doug's Headers from Pacific Performance Racing. Call Ken at Pacific Performance Racing at 310-832-4596. You can order from Performance Years on line or via phone or fax.
Both companies carry them in stock.
Old 06-21-2004, 01:04 PM
Ccass's Avatar
Administrator
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by formula_73:
Now i have a problem. I just found out that the headers I got won't fit with my type of heads. They were made for HO/SD/RaII & IV type heads. I have 4X heads. I noticed when double checking to buy my system I was about to get the #RFE93BKQ or #RFE93CK2 set but didn't know what the difference was. I'm assuming it was just the muffler type. But now I think I'll be needing either new headers or new heads. <HR></BLOCKQUOTE>
If you order your Doug's headers from Pypes, you need RFP115R or RFP115RC (ceramic)
Old 06-22-2004, 04:16 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Ccass, correct me if I am wrong but you said he needs to use RFP115R. Thats a round port header isnt it? He has 4x heads, I am not too familiar with 4x's but I thought they were D ports? I dont think he wants to end up with 2 useless sets of round port headers. If I am correct on this hopefully somebody will catch it before he orders up another wrong set. If I am wrong, well I had good intentions and now I will know better next time
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 06-22-2004, 04:57 PM
Ccass's Avatar
Administrator
whoops! Sorry, I read to fast. I saw HO/RA and assumed round port. The correct part number would be RFP115 OR RFP115C (polished ceramic)
