Hi All, Hey, I know this has probably been addressed, but what are the specs on the Ram Air 4 cam?????? lift, duration, centerline, etc.... Also, being new, I would like to know what is meant by an "N" crank in my '71 400 engine? Forged vs cast???
Thanks, Phil |
Thanks, Phil |
The RA IV cam specs are:
230/240 duration @.050 .469/.469 114 LSA
1965 GTO Hardtop - Fontaine Blue, Blue interior, 389 Tri-Power, 4 speed, 3.36 posi, Rally I's |
Hey trips have you had a chance to go to the track with your new cam yet?As mine is going in next weekend and was wondering what kind of time you picked up?
Hey! Thanks. With that lift and 114 LSA why would you need the Rhoads lifters???
Inquiring minds! Thanks Again, Phil |
The Rhodes help with low end power loss brought on by running alot of duration. If you are running the gear, converter, and other components suited to that cam, you won't need them. But they will help idle quality and low speed drivability.
Also, no factory Pontiac cranks are forged.
'68 Firebird-462-6X's-Worked CI intake-Cliff R. prepped 800 Q-Jet-Crower RAIV clone w/1.65's-10" Continental-3.08 gear-12.84 @ 109 on hard street radials. |
Hey Grand! How ya doin, man... No I did not make it to the track.. it was threatening to rain last Thursday and it did rain on Friday so that shot that is the a$$... will try again this Thursday! Jim
Cool Man I am doing awesome! Hope you make it this thursday!!What were your best times before with the speed pro .214 one?>
Sorry to hijack your post HotRod2go...
Grand... the wife just informed me I am NOT going to the track on Thursday or Friday...prior commitments.. oh well. there's always next week ![]() 60 ft. 2.36 330 ft. 6.30 1/8th 9.62 @ 73.92 These times were with a 3200 rpm launch and shifting at 5000. The best 60ft times on that night was a 2.31 but all were in the 2.3X range. Jim
Hey Grand... I just got a pass to go to the track on Thursday .... If I get there at 6pm when they open I should have time for 2-3 passes before I have to get back. I will post the results on Friday!! Jim
Thanks Jim looking forward too them!.....Also sorry hotrod2go for hijacking
Hey Guys,
No problem on the hijacking!!! LOL I look forward to seeing the numbers too!!! Take Care! -Phil |
OK guys.. here we go.... drumroll please
![]() With the new SpeedPro 1175 cam and 215/70R14 street tires my best time out of 5 passes (this is the 5th pass): 60 ft. 2.27 330 ft. 6.20 1/8th 9.49 @ 74.38 Details... very slick track.. had a heck of time figuring out how to launch it. It either wanted to smoke the tires or I had to walk it out... the posted times were with a 3000 launch to get it rolling, punching it and then 5000 rpm shifts. Some improvement over the 1022 but not as good as I expected. I was hoping for a 9.2-9.3. Obviously drag radials would make a difference but this is a good apples to apples comparison. Have a great weekend guys! Jim
Wow I am surprised thats all you gained,...Even factor out the traction issue your mph does not indicate all that extra hp you got with the new cam?Either way you need tires and then go back that will be the only way to see what kind of #'s you can run....If everything goes as plannedI am putting mine in on sat and racing on sunday ,and I will post the results,But atleast you improved! How did it feel trips?Was there alot stronger mid range pull or did you only race 1/8?Actually trip if you were to do the math thats almost .3 gain in the 1/4!
Hey Grand... I raced the 1/8th because that is all they have at this track. I guess .3 in the 1/4 isn't bad when you think about it... Maybe my expectation of .4 in the 1/8th was a bit unrealistic. So, this cam does pull well once I get it over 3000. Not a lot of bottom end in the ol' 389 but she pulls real well mid range up. It's right on the edge of being to much for this engine but ol' Doug Christie loves this cam in his 455!! I love the way it sounds... nice lope. Jim
Cool! Yeah it is right on the edge... are your heads ported?I think if you theoretically picked up almost .3 There's no reason why I can't see .5
The RAIV cam was used with 1.65 ratio rockers, giving .520 lift
http://www.stockappearingdrags.com http://www.stockappearingdrags.com Come on get off that lawn chair and drive that car like it was meant to be driven. 69' 400 RAIV Judge Conv... 12.86@107 Factory Stock 69' 400 RAIV Trans AM .....12.48@110 Factory Stock 69' 400 RAIV Judge HT..... 13.07@104 Factory Stock 73' 455 SD Trans AM........13's?? not run yet 66' 455 GTO Convert.........12.20@112 non original 63' 421 SD Catalina...........restored fast as h*ll |
Gonz... yea your right IF you are using 1.65's and yea we know that the original RA IV engines used 1.65's. That pretty much applies to all cams though....
Grand....my heads are pocket ported only. I think .5 is realistic in your combo.... you got lots more bottom end to play with! LOL! Let me know!! JIm
Man I hope so Trips!!!!!!! Last time you were at the track with the old cam did the car spin as much or feel as powerful down low as it did with this cam?That would give me low 13's!
![]() I can hardly wait 5 days and counting
Oh yea, grand!! That old cam would smoke tires all day but ran out of juice at about 4k...I think the 1022 is a better all around street cam for my engine. May change it back... may not.. the 1175 cam still outperformed it but bottom end is a good thing for everyday street performance. They both have here +/-'s so it's really a toss up at this point. I think with some better heads and a bit more compression that the 1175 would really come alive. But, I'm not complaining about it considering the spec's on the engine I have. I also am hoping to go to a 3.55:1 ratio later on and I think that will help as well.
