Old 10-02-2003, 04:03 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Found a 400 motor for sale...
Block code: 149369XH
# by distributor: J098
4X Heads...these are the numbers I got from them:
A2931
A2431
GM 8
I didn't see any 1H, 3H, 4H, or 7H....any help would be much appreciated, as I'm making the decision to buy or not!!
Thanks!!!
Darin
69 LeGTO- 350/350 soon to be 400/350!
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Jagtec1's Avatar
A2931
A2431
GM 8
Thanks!!!
Darin
Darin
9.81 @ 136.39MPH
Old 10-02-2003, 05:42 PM
Jagtec1's Avatar
Disregard the 1 at the endof the head date...think that was an extra! So...27 views and no input yet...hmmm.
Darin
9.81 @ 136.39MPH
Old 10-02-2003, 07:54 PM
MR. May MR. May is offline
the block is october 68' and the heads are january 73'
Old 10-03-2003, 07:13 AM
gotpontiac gotpontiac is offline
The heads as stated above are '73 model.
Do they have press in or screw in studs?
Press in large valves they are 1H 114cc or 3H 98cc
Small valves are 4H 98cc
Screw in studs are large valve 7H 98cc
Those are approx cc's and the 1H are the 455 heads.
Greg
Greg
1969 Firebird/400/th400/3.42:1 rear
1/4=? MPH=? (WIP)
1983 1/2 ton Silverado/lwb/305 (89 FB)/
MSD ign/Mallery coil/83 intake/
700-r4(rebuilt w/shift kit and corvette servo)/
3.73 gears/31x10x15 all terrains.
10.9 1/8 mile. 17.xx 1/4 mile
1996 C2500/6.5L TD/4L80e(shift improved),4" exhaust
cold air intake, mechanical WG controller
3.73 gears/265-75-16 w/Eagle allows.
2002 1500 Suburban/stock
1986 Fiero GT,needs engine.
Old 10-03-2003, 07:27 AM
johnta1 johnta1 is online now
The 1H,etc. is stamped on the head.
Here is a pic.
johnta1
Old 10-03-2003, 09:55 AM
Injunjoe Injunjoe is offline
Ahh ok. The Head ID number is cast into the center exhaust ports Jag. Those are I believe 1975 400 heads they are about 101 cc's if I remember correctly. Very similar in potential to a set of 6x's according to Dave at SD Performance.
Joe
Old 10-03-2003, 07:54 PM
Jagtec1's Avatar
They are 4X 4H small valve heads...98cc. I'm assuming these would be OK on this motor for good low end??
Darin
9.81 @ 136.39MPH
