Old 06-25-2004, 01:09 PM
Mr83 Mr83 is offline
Does anyone know if HM coded 15 inch Rally II wheels will fit a 83 Grand Prix that orginally came with 14 inch wheels? Thanks
Old 06-26-2004, 07:39 AM
if it has the 4.75 bolt spacing it should work.
mike
former." --Albert Einstein
- Winston Churchill
Old 06-26-2004, 09:18 AM
Thanks Mike. I tried to install them this morning and ran into a problem. I have brand new Wheel Vintiques center caps installed. The front wheel won't fit with the center cap on. Rear is fine. Seems the locking plate and screw are in the way. Wheel fits without the center cap on. Anyone else run into this problem? Is there a way to install the Wheel Vintiques w/o their installation mechanism?
Old 08-13-2004, 07:26 AM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
Tino,
The wheels will fit fine on the '83 Grand Prix, but as you found, you cannot use the aftermarket centers that bolt on. The spindle is too long and will interfere with the lock nut and stud on the center cap mounting plate. I have run a 15" rallye on my '83 for years. I switched my center caps back to the factory spring retaining plate and have had no fitment issues. The other alternative will be using spacer plates between the rim and rotor.
P.O.S.I - It's not just a club...it's an addiction!
