Old 11-25-2004, 11:01 AM
co9738 co9738 is offline
Hi I am new to this forum. I have a 1978 Firebird with a new 403. But I am not getting any spark new coil module. Not sure what to check next I have two good ground on the engine. Please help? Thanks
Old 11-25-2004, 11:11 AM
tom8461 tom8461 is offline
Make sure the 12v lead is connected at your cap tightly. Mine pulled out once and killed the motor right there.The wire is kinda pinkish -red and goes in the top of the cap next to the tach-coil connector......Good luck with the car
Old 11-25-2004, 12:36 PM
That was one of the first thing I check still no luck. Engine cranks no spark.
Old 11-26-2004, 12:39 AM
wyorm1mechenic wyorm1mechenic is offline
im assuming you have hei ignition.have you checked to see that u have power to distributer????ignition on..
Old 11-26-2004, 09:52 AM
grandville455's Avatar
grandville455 grandville455 is offline
pickup coil maybe?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
