Old 08-04-2003, 07:22 PM
67mdesch400's Avatar
67mdesch400 67mdesch400 is offline
new 406ci in my 67 Firebird
new 750cfm edelbrock carb
new holley pump gas and regulator
new spark plugs, wires, rotor and distributor cap
car ran well for 3 months but just start to bug over 4000 rpm. I can use the car without any problem as long as I dont accelerate strong over 4000 rpm. I don't know if it's missing gas or sparks.
Does anybody have an idea where I should look first??
http://firstgenfirebird.org/show/closeup.mv?CarID=341
Montebello, Quebec, Canada
Old 08-04-2003, 08:03 PM
ontheblocks ontheblocks is offline
By Bugging, I'm guessing you mean that it has a stumble or a miss above 4000 rpm!? If so, it is more than likely either spark or gas. Can you reproduce the problem with the car not moving? Or does it only happen while you are driving?
Things to check:
Fuel filter
Fuel pressure (at 4000rpm)
bent or misadjusted secondary linkage on carb
distibutor cap on properly
worn/damaged contacts in the distributor cap
broken or melted spark plug wire
coil connectons, or bad coil
You don't say what distributor you are using, HEI? Mallory? Any add on controllers? When it "bugs" do you smell gas, or get backfires through the carb? A little more info can help find the problem quicker!
If it has ti*s or tires, it's gonna cost ya!
Old 08-05-2003, 03:55 AM
yes it bugging on each gears and neutral and it doesn't smell gas.
I have factory HEI, module and coil.
Old 08-05-2003, 05:38 AM
Could possibly be the control module in the HEI, but those usually cause the car not to start at all. I'm thinking it is more of a carb problem, check your pressure after the regulator, with the engine running at idle, then increase rpm's and monitor the pressure. Your fuel filter could be partially clogged, or your regulator could be bad or need adjusting. Hope this helps.
Old 08-05-2003, 07:08 AM
79TA455's Avatar
79TA455 79TA455 is offline
Weird. Mine is doing the same thing but @3000 rpm. It only does it in gear I beleive though. No back fires through carb or smell of gas.
I have a few things that I want to do including replacing the fuel filter. My vac. advance is not functioning either so that may be hurting me too. Plugs definitely should replaced. Guess that I will keep an eye on this post.
<A HREF="http://www.geocities.com/rpk76/1979.htm" TARGET=_blank>79TA455
</A>
Old 08-05-2003, 02:49 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
What type of Carb are you running? I had a factory quadrajet drop a secondary jet needle. It fell down into the jet & the car would not rev over 4K. It did not miss bad though. It just would fall on its face. Once I pulled it apart, I also found the float level was too low in the bowl. I don't think that was helping anything either.
68ragtop
1968 GTO Convertible (currently my resto project)
1978 Gold Edition Trans am
1979 10th aniversary T/A
1980 Pace Car Trans am
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 08-05-2003, 02:55 PM
SupergasDil's Avatar
Coil could be taking a dump.
Old 08-06-2003, 02:21 AM
goatseeker's Avatar
goatseeker goatseeker is offline
Mine did exactly the same thing at exactly the same rpm. Bad coil - replaced it and the problem instantly went away.
Agree with Larry that bad module would probably cause the car to not start. Poor fuel supply would likely cause it to fall on it's face rather than stumble.
If the stumble goes away when you let up on it I'd put my money on the coil.
http://kurtspontiac.homestead.com/TimSimpson66GTO.html
Old 08-06-2003, 10:07 AM
79TA455's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by 68ragtop:
68ragtop<HR></BLOCKQUOTE>
I have a 750 Holley single pump, double feed.
</A>
Old 08-06-2003, 10:38 AM
Crashmh's Avatar
Crashmh Crashmh is offline
A couple other things to check:
What is the voltage (while running) at the coil (+)? It should be full battery voltage (13-14v). If the factory resistance wire from the ignition switch to the coil wasn't replaced or bypassed when the HEI was installed, it will cause a weak spark, missing, and low power at higher RPM's.
Also, if you're running the stock coil, they are notorious for getting weak with age.
Old 08-07-2003, 04:21 AM
I'm not sure yet but I found the gas line bend direct at the carb connector under the air filter. But I cannot try it yet and hit the throttle to make it happend because it's raining like hell every night since then.
So before to go farther I'll wait to test that.
Old 08-10-2003, 02:15 AM
Going to the track tomorrow, I should say today and I can't wait.
Have you ever seen a factory HEI coil missing fire only over 5500 rpm? I resolved the gas problem but now once and a while it is doing back fire in the exhaust when I hold it over 5500. New cap, rotor, wires.
Old 08-11-2003, 03:56 AM
went to the track but it was raining.
